Hi, I need the following chassis parts for Hay Wagon to Speedster project https://mtfca.com/phpBB3/viewtopic.php?f=2&t=13134 Will be driving Houston to Mount Rushmore South Dakota 07/10/2020 and back 07/15/2020
Running board mounts and steel strap that holds them up.
Battery holder.
Drag link.
All parts of the brake lever including the mounts and the thing with the teeth.
Steering column, steering wheel.
Rear axles, my key ways are worn out.
Anything else I might need that I haven't thought of yet...
Chassis parts for Hay Wagon to Speedster project wanted.
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
Re: Chassis parts for Hay Wagon to Speedster project wanted.
Have it all, less steering column!
Topic author - Posts: 913
- First Name: Ignacio
- Last Name: Valdes
- MTFCA Number: 50406
Great! Now how to get it? I will be heading Houston Texas to South Dakota next week but South Pittsburg is a ways off East...
- Last Name: Eyre
- * REQUIRED* Type and Year of Model Ts owned: 1913 Touring 1914 Touring and Roadster 1915 Touring 1926 Roadster
I have a hand brake quadrant with four holes that mount to the frame good teeth. Yours for the cost of shipping.
meyre14t@yahoo.com
meyre14t@yahoo.com
- * REQUIRED* Type and Year of Model Ts owned: Speedster (1919 w 1926)
You might consider a drive by stop at Model T Haven in Iola, KS. Not to far off your path.
https://modelthaven.com/component/conte ... Itemid=130
- Last Name: Valdes
Planning on stopping into Model T Haven. Here is my current list of parts wanted:
Battery holder.
Drag link.
All parts of the brake lever including the mounts and the quadrant.
Motor shelves -- also have to figure out how to do the transition on the front chassis brackets.
Nice key switch
Coil box enclosure and coil boxes, 2 sets of 4 total 8.
Brass windshield frame
Rear brake lever at the hub. Have new cams, need the single rivet lever. I have 1 already.
Brake rod radius rod clip.
Battery cables.
Foot starter switch.
Gas tank for speedster.
Battery holder.
Drag link.
Nice key switch
Battery cables.
- Last Name: Valdes
2nd largest front early tapered leaf spring.
