Full Flow Float Valves by itself... in stock: $25
Float valve install tool, limited quantity in stock, and only available with purchase of valve - add $40
And finally (no picture) a Lead washer to ENSURE no weeping past carb/valve interface, only available with purchase of valve. This replaces the hard red washer that so frequently fails to seal as expected - add $3
Postage for one, some or all: $8
Emails only please, no PM's. Also, I do not frequent this site as often as I used to, so a response here may be missed.
Last call for 2020: FS - Full Flow Float Valves, valve install tool, and lead washer
Topic author - Posts: 6435
NH Full Flow Float Valves
Re: FS - Full Flow Float Valves, valve install tool, and lead washer
...and again...
- First Name: Ray
- Last Name: Malzo
I have a model G Holley, do you float valves work on this carb? If so I would like to purchase the valve, the tool etc. Let me know, thank you
- Last Name: Hatch
- MTFCA Number: 49974
Email sent. Dan
Also: if you ever work on an NH, you need this valve tool. Thanks Scott for making them, save me the trouble. Dan
..and again..
Last call for 2020. Not going to keep pimping these things and annoying folks wanting to see their ads on top. The last of these will likely go to a couple of buyers who buy bulk, so if you thought you wanted one, now is the time.
Thanks for looking and have a safe time for the remainder of summer and into fall/winter.
