This is a nice set of used triple gears and driven gear. This is a matched set that has ran with each other. I always keep the four gears together when I find a nice set. I also have a set of new bushings and new triple gear pins that I recently bought from Langs. I bought the pins and bushings to use on my speedster project engine rebuild. I found out my flywheel was bad, so I had to get another flywheel. The replacement flywheel had pins and triple gears good enough to use as is. So I have these parts extra. I was going to use these on my own car. I think the old bushings are good enough to re-use on a moderately driven car. I protected the bushings when I glass beaded the gears. Old bushings are probably not good enough for a high speed speedster or a long distance tour car. Im including the bushings and pins, so a person could change them if they wanted to.
Ill take 150.00 for all. plus 13.60 shipping anywhere in continental US. Actual shipping cost anywhere else.
I accept pay pal, personal check, or money order.
If you have any questions please use the contact info in one of the photos, do not send a PM message.
please excuse the order of the pictures, they post in the order "they want to"
For sale triple gears, pins and bushings.
Topic author - Posts: 1285
- First Name: Donnie
- Last Name: Brown
- MTFCA Number: 49575
- Last Name: Brown
- Last Name: Brown
Re: For sale triple gears, pins and bushings.
Spoken for, pending payment .... Thanks mtfca ....
