For Sale - Johns Manville Speedometer Drive Joint
DontKnowMuch
Last Name: Sanford
Post by DontKnowMuch » Tue Jul 28, 2020 11:41 am
For Sale is a 1923-27 Johns Manville Drive Joint. It is a one-piece drive joint that placed the output shaft at 45 degrees. It is a 1 to 1 ratio and is marked on the flat surface in two places as "1 to 1 A". The right angle bar and clamp are marked with the JM part number T-136 but are interchangeable with Stewart brackets. The drive joint moves freely but it needs to be cleaned better and lubricated. I am asking $125 plus postage.
I have been told that this may work with other speedometers that use a 1 to 1 ratio. Let me know if you have any questions.
