For Sale is a 1923-27 Johns Manville Drive Joint. It is a one-piece drive joint that placed the output shaft at 45 degrees. It is a 1 to 1 ratio and is marked on the flat surface in two places as "1 to 1 A". The right angle bar and clamp are marked with the JM part number T-136 but are interchangeable with Stewart brackets. The drive joint moves freely but it needs to be cleaned better and lubricated. I am asking $125 plus postage.
I have been told that this may work with other speedometers that use a 1 to 1 ratio. Let me know if you have any questions.
For Sale - Johns Manville Speedometer Drive Joint
Topic author - Posts: 205
- Last Name: Sanford
- * REQUIRED* Type and Year of Model Ts owned: 14 Touring, 26 Roadster, 27 Roadster
