Corbin speedo cable/parts.
Post by Allan » Fri Jul 31, 2020 4:45 am
I need a 56", or a bit longer, Corbin speedo cable. Just the cable housing without the inner would suffice. Failing that, just the swivel end ferrule and nut would do. I have a 48" cable outer, but that is likely for use on a Harley or Indian motorcycle which had the speedo on the fuel tank and a fixed drive at the rear axle. I do not want to bastardise it just to get the end I need.
If it's any help, I measured the male thread to which the needed ferule fits as .800" diameter, 24 TPI.
