FS AUXILIARY TRANSMISSIONS
Mark Chaffin
Last Name: Chaffin
MTFCA Number: 31705
Post by Mark Chaffin » Sat Aug 01, 2020 12:39 pm
I have a few auxiliary transmissions available for purchase. All but the top left unit are of the Warford variety. I have been unable to identify the manufacturer of the top left unit as there are no markings. Price for this unit is $200. The top two Warford transmissions are cast iron and the gear appear to be in good condition. Price is $300 each plus actual shipping. The Warford transmission shown below is of the aluminum variety. The unit turns freely and the gears appear to be in good condition. Price is $400 plus shipping. I also have a couple of aluminum shifter bodies. Price is $100 plus shipping. First come first serve. Message me or call Mark Chaffin (951) 805-0928
Mark Chaffin
Last Name: Chaffin
MTFCA Number: 31705
Re: FS AUXILIARY TRANSMISSIONS
Post by Mark Chaffin » Sun Aug 02, 2020 11:53 am
One Warford sold to Brian. Thanks Brian! Thanks MTFCA!
Mark Chaffin
Last Name: Chaffin
MTFCA Number: 31705
Post by Mark Chaffin » Sun Aug 02, 2020 3:36 pm
I noticed the cast iron Warford unit shown in the top right portion of the photo has had some weld repair on the case; however, the gears look pretty good. I'm sure it will function as intended. Because of the cosmetic issue (weld repair), the asking price for this unit has been reduced to $200 plus shipping. Thank you all for the interest.
Mark Chaffin
Last Name: Chaffin
MTFCA Number: 31705
Post by Mark Chaffin » Sun Aug 02, 2020 3:51 pm
Warford cast iron shifter assembly sold to Wallace. Thanks Wallace.
Mark Chaffin
Last Name: Chaffin
MTFCA Number: 31705
Post by Mark Chaffin » Sun Aug 02, 2020 6:32 pm
Bottom right shifter assembly promised to Terry. Thanks Terry
Mark Chaffin
Last Name: Chaffin
MTFCA Number: 31705
Post by Mark Chaffin » Sun Aug 02, 2020 7:56 pm
Aluminum Warford and Shift Lever Assembly has been sold. Thanks Tom!
Post by Wayne Sheldon » Mon Aug 03, 2020 3:42 am
For what it is worth. I had one of the little two speed (direct and under) transmissions (not yet sold in the viewer's upper left corner) many years ago. I was told it was a "Jumbo" Junior, by the same makers of the Jumbo Giant. I later did see (but do not have a copy of) an advertisement for them which supported the "Jumbo" connection.
I never did use the thing, so don't have any personal insight on how good or bad they are.
Post by Wayne Sheldon » Mon Aug 03, 2020 3:47 am
Somebody needs to buy that last Warford needing the weld repair. I am very tempted but have no business buying something I just really do not need right now.
John M Maslack
Last Name: Maslack
Post by John M Maslack » Mon Aug 03, 2020 7:21 pm
Mark, It's hard to tell from the angle of the photo, but I think the first one is a Woodward auxillary. They are a two speed with either direct and under or direct and over...John.
Mark Chaffin
Last Name: Chaffin
MTFCA Number: 31705
Post by Mark Chaffin » Mon Aug 03, 2020 9:32 pm
Hi Wayne,
Thanks for the plug. To clarify, it has been repaired. The weld repair looks like it was done by someone who knew what the were doing. Aside from the repair, it should function as intended.
Mark Chaffin
Last Name: Chaffin
MTFCA Number: 31705
Post by Mark Chaffin » Mon Aug 03, 2020 9:33 pm
Hi John,
It may be a Woodward as it is similar in appearance. The gears look pretty good inside.
John M Maslack
Last Name: Maslack
Post by John M Maslack » Mon Aug 03, 2020 10:07 pm
I have one in decent shape...They use Hyatt bearings. I have never run the one I have.
Mark Chaffin
Last Name: Chaffin
MTFCA Number: 31705
Post by Mark Chaffin » Tue Aug 04, 2020 10:59 am
ASKING PRICES FOR THE REMAINING ITEMS ARE NOW AS FOLLOWS:
#1 $175.00
#2 $175.00
#3 $75.00
Actual shipping will be an additional charge. Thanks :)
Mark Chaffin
Last Name: Chaffin
MTFCA Number: 31705
Post by Mark Chaffin » Wed Aug 05, 2020 1:28 pm
#1 pending possible sale to Mark.
Mark Chaffin
Last Name: Chaffin
MTFCA Number: 31705
Post by Mark Chaffin » Wed Aug 05, 2020 9:47 pm
#1 is still available. Mark wanted an overdrive. This is an under drive (like a Ruckstell) two speed. Forward is direct 1:1 and the the rear is 1:2 ratio. Turns and shifts easily. Gears are in good condition.
Post by Wayne Sheldon » Fri Aug 07, 2020 8:12 pm
I wish someone would buy number 2. It is so tempting, but I do not need it. And there are some things I DO need.
Bump.
Mark Chaffin
Last Name: Chaffin
MTFCA Number: 31705
Post by Mark Chaffin » Mon Aug 10, 2020 8:34 pm
#1 sold to Mark. Thanks Mark!
Mark Chaffin
Last Name: Chaffin
MTFCA Number: 31705
Post by Mark Chaffin » Mon Aug 10, 2020 11:29 pm
Price reduced to $150 plus shipping for #2. Wayne?
Post by Wayne Sheldon » Tue Aug 11, 2020 3:56 am
Grr. Any idea what shipping would be? Could the grapevine get it to Erik Barrett's in Auburn? I really don't need one at this time. It IS awfully tempting? The price is right! How decent do the gears appear to be? I do have a half blown one just like it with some decent parts still.
Mark Chaffin
Last Name: Chaffin
MTFCA Number: 31705
Post by Mark Chaffin » Tue Aug 11, 2020 10:54 am
If you can use it, I'll cover the shipping. I'm sure you will put it to good use. :)
Post by Wayne Sheldon » Wed Aug 12, 2020 7:51 pm
Dog-gone, you are dang near giving it away! If you cannot get a better buyer by tomorrow? I guess I can scrape up $150, and hopefully put it to good use. Next I need to figure out how to get the money to you. Thanks to the good bank I have liked and used for thirty years being bought out? I no longer have checks I can mail. I guess a PO money order? (I really don't like them either.)
Mark Chaffin
Last Name: Chaffin
MTFCA Number: 31705
Post by Mark Chaffin » Wed Aug 12, 2020 7:58 pm
Whatever works best for you my friend. Give me a call and we can work out the details.
Mark Chaffin
Last Name: Chaffin
MTFCA Number: 31705
Post by Mark Chaffin » Wed Aug 12, 2020 7:59 pm
