OT Dodge Brothers 1920 gas cap needed
Topic author - Posts: 4967
- MTFCA Number: 52564
Any one have a Dodge Brothers gas cap that would fit a 1920 kicking around? The threads on the tank are about 2-1/2 inches and 13 TPI. The top is 6 sided on a larger round base. (as I recall) Or even just a cap that would fit would work,.
1920 Dodge touring
1920 Dodge touring
- First Name: Nevin
- Last Name: Gough
- * REQUIRED* Type and Year of Model Ts owned: 1918 Light Delivery
Re: OT Dodge Brothers 1920 gas cap needed
Who would have a DB, and be on a MTFCA site?? : )
David Dewey, Gene French, and about six others I know of?
Don't forget most everyone that has a T built before 1914, well at least in part.
1920 Dodge touring
1920 Dodge touring
- First Name: Gene
- Last Name: French
- MTFCA Number: 15614
- Board Member Since: 2014
Mark:
i will look around in my DB parts ... i am sure i have a cap IF i can find it ... am currently adding on my shop building and have stuff piled on top of piles of stuff ... too much stuff ! always an optimist ...Gene French
Great and thank you Gene.
1920 Dodge touring
1920 Dodge touring
- First Name: David
- Last Name: Dewey
- MTFCI Number: 19936
Glad Gene probably has one, I couldn't tell you where my DB gas tank stuff is right now. However, I do see them on eBay frequently. They don't seem to be uncommon like some DB parts are!
And Wayne was right!
T'ake care,
David Dewey
David Dewey
I have been watching eBay, even using different search parameters, so far no go. I checked with Myers Early Dodge, LOL I am use to T parts prices and expect higher for Dodge and Chevrolet so when they gave me a price of 45 plus shipping for a used cap, time to do more looking.
1920 Dodge touring
1920 Dodge touring
- First Name: Terry
- Last Name: Horlick
- * REQUIRED* Type and Year of Model Ts owned: 1927 Roadster Pickup "Mountain Patrol vehicle" from Los Angeles City Fire Department and a 1912 Model T omnibus restoration project
- MTFCA Number: 50510
Erik Barrett took his Dodge Brothers on a tour I was on about ten years ago.
- First Name: David
- Last Name: Dewey
I drove Erik's DB on a tour two years ago, took his Dad along, likely one of his last tours. Had a great time! But wish the DB brakes were a little better. Will have to see what I can do to mine when I get it back together. (after the Ts!)
Mark, did you find a cap yet?
T'ake care,
David Dewey
David Dewey
Not yet. Have and ad on AACA but no luck so far. glad your ok. I am going to check a wrecking yard down in Springfield next week and see what they might have.
1920 Dodge touring
1920 Dodge touring
- First Name: David
- Last Name: Stroud
- Board Member Since: 2011
Mark, quick question. Are the threads the same as a T tank? In other words, would a T cap fit the Dodge? My '25 coupe has a cast iron cap that sounds similar to what you need, I have no idea where it came from. Dave
1925 mostly original coupe.
No, the threads are external on the neck (male), internal (female) on the cap. Thanks for checking.
1920 Dodge touring
1920 Dodge touring
Saw this on eBay. sort of matches your description: female threads and appears to be six sided. https://www.ebay.com/itm/Antique-Boyce- ... Sw31pfZ0-i
- First Name: David
- Last Name: Dewey
Sorry Frank, that's a radiator cap. The cap Mark is looking for has a long "tit" on it, fairly unique piece that I've not seen on any other cars. here's a rough sketch of one from memory;
T'ake care,
David Dewey
David Dewey
- Last Name: Strange
- MTFCA Number: 30944
- MTFCI Number: 23667
- Board Member Since: 2013
I think the one shown on the aaca thread is earlier. As far as I know that style would work, but think Dodge got rid of the tower and added a splash shield on the inside, like some of the T gas caps. Other wise the shape is the same as posted in the link. If I don't find one soon, am going to solder the neck off a Model A gas tank on. Would be easy to remove later and gas caps are a plenty.
1920 Dodge touring
1920 Dodge touring
