FS MISCELLANEOUS GOODIES
Topic author - Posts: 3327
- Last Name: Chaffin
- MTFCA Number: 31705
What we have here is an assortment of various goodies. Prices and shipping are as indicated below. Combine and realize a possible savings on shipping. Message me or call Mark Chaffin (951) 805-0928
AC Speedometer cable and drive arm bracket $25.00. Plus $15.50 shipping.
Carburetor adjustment rod (13-22) $40.00. Plus $15.50 shipping.
Early metal coil box. Latches function as intended. $20.00. Plus $15.50 shipping.
Early driveshaft spool sleeve lock screws NOS (12 pieces). $20.00. Plus $8.50 shipping.
Ton Truck HYATT Drive Shaft Roller Bearing and Sleeve In The Box. Some light rust. Appear to be NOS. $100.00 SOLD
Re: FS MISCELLANEOUS GOODIES
Oil pressure system timing cover pattern and brass gear drive oil pump $100.00. SOLD
Ton Truck adjustable rear brake arm and cam set NOS $25.00. SOLD
Accessory Air Breather Cap $25.00. SOLD
Front outer adjustable wheel bearings (4 pieces) $30.00. SOLD
Last but not least. Although not Model T related, one pair of Babbitt role up door sprockets. Get the pair for $50.00 plus $21.50 shipping.
Front wheel bearings and accessory oil breather sold to Rich. Thanks Rich!
TT HYATT Bearing and sleeve sold.
Oil pump and pattern sold to Layden. Thanks Layden!
TT Brake arm and cam set sold to Rich. Thanks Rich!
