Model T Parts For Sale
Posted: Sun Sep 06, 2020 3:32 pm
Anyone needing a nice set of '17 - '22 ('23) windshield hinges ? Correct tension nuts - $60 for the pair includes Priority Mail in the U.S.
Also some upholstery end caps - might be NOS but not stored too well - mostly surface rust - only have 2 large for $25 & 8 small - 2 small for $20 includes Priority Mail in the U.S. Drop me a note through here, please.
Re: Model T Parts For Sale
Posted: Sun Sep 06, 2020 4:30 pm
by sweet23
e-mail sent
Posted: Sun Sep 06, 2020 8:32 pm
Nothing came through, Darryl.
Posted: Sun Sep 06, 2020 9:33 pm
by sweet23
I just sent one, direct to your e-mail, hope that worked
Posted: Mon Sep 07, 2020 3:51 am
by Wayne Sheldon
The windshield hinges are '15 to early '17.
Posted: Mon Sep 07, 2020 10:49 am
No, they're not Wayne - they are NOT equal length !
Posted: Mon Sep 07, 2020 11:16 am
Forgot to add these - $25 a pair includes Priority Mail in the U.S. - drop me a note through here, please. I'll measure again but I believe the wider one is 1" & the other was about 3/4". They both have an "anchor" imprinted on them.
Posted: Mon Sep 07, 2020 1:52 pm
My apologies Wayne - indeed those are the '15-'16 - I posted the wrong info & price ! The corrected price is $75 for the pair.
I do have 3 of one side of the unequal length hinges !
Posted: Mon Sep 07, 2020 5:05 pm
by Wayne Sheldon
No worries Steve T. I spent some time restoring a really rough pair of '15/'16 hinges, and got to know the several little details of them. Nearly all the visible pieces are different than the later ones.
"Equal length" is a bit of a misnomer, as the "front-to-back" offset of the hinges causes a bit on inequality. The "up-to-down" of the hinges is roughly equal on the earlier ones, and results in the glass edges being nearly lined up when folded. The other part of that equation is that the bolt holes on the upper frame are also different from the later upper frames. On the later windshields, when all proper pieces are used, the folded windshield holds the upper frame about an inch and a half higher than the early windshield does, giving driver and passenger just a bit more protection.
The '14 style hinge is very similar to the '15/'16, except that the upper and lower frames line up straight if positioned straight out (no offset). The detent dimples for the '14 are different than the '15/'16 also.
Nice looking pair of hinges! However, I don't need another pair.
Posted: Mon Sep 07, 2020 5:50 pm
Appreciate your consideration !
I'm familiar with '14 hinges as I have a '14 Touring also.
Posted: Mon Sep 07, 2020 10:10 pm
W.S. hinges found a new home as well as some of the upholstery caps - Thanks MTFCA !
Posted: Wed Sep 09, 2020 11:18 am
All the small upholstery caps are spoken for - have a pair of the large ones left & the w.s. strap hooks - I believe those are used with the "webbing" straps for '15 & later - not the leather straps.
Thanks MTFCA !
Posted: Thu Sep 10, 2020 5:52 am
by Brian D
I will take both pair of strap hooks.
Brian
Posted: Thu Sep 10, 2020 11:37 am
I'll hold them for you Brian - drop me a note through the Forum & we'll discuss the particulars.
