NH Striaght through Carb
Topic author - Posts: 576
- First Name: Bruce
- Last Name: Compton
NH Straight through carburetor. Rebuilt, tested, and guaranteed. This one has a new viton needle valve, pressure tested original float, cleaned internal passages, new choke spring, zero wear on the throttle shaft/bore, and is the later version with the steel throttle arm. Asking $295.00 (check) or $310.00 (pay-pal) including shipping.
- Last Name: Gember
- * REQUIRED* Type and Year of Model Ts owned: 1922 Touring 1926 Runabout 1926 Coupe
- MTFCA Number: 32303
- MTFCI Number: 16589
Re: NH Striaght through Carb
Sent you a pm. MAG
- First Name: Bruce
NH Straight through is on it's way to Mark. Thanks MFTCA
