Wanted: set of Grant brand .030” rings for aluminum pistons
Topic author - Posts: 1414
- First Name: Adam
- Last Name: Doleshal
- MTFCA Number: 23809
- MTFCI Number: 1
Email me (don’t pm). Thanks!
- Last Name: Hatch
- MTFCA Number: 49974
Re: Wanted: set of Grant brand .030” rings for aluminum pistons
Email sent. Dan
- First Name: Adam
- MTFCI Number: 1
I’m no longer in need of the rings. Thanks!
Dan, I just emailed back.
- First Name: craig
- Last Name: leach
- MTFCA Number: 26647
I think most aluminum pistons use 1955-1956 chevy 265 cu.in. rings so you can buy them by bore size ie. Std, 10-20-30-over from some suppliers. You do get enough for two engines when you buy a set
- Last Name: Hand
- * REQUIRED* Type and Year of Model Ts owned: 1912 open express, 1920 touring, 1926 tudor-lisenced and insured, 1921tt project 1922 fendered chassis, 192x tt dootle bug 192xengine w/winch projects
- MTFCA Number: 28114
- MTFCI Number: 21834
The top ring groves for an Aluminum Model T Piston are .125", for the 265 ci chevy they are 5/64", oil rings are both 3/16th"
