Re-Babbitting service , Model T main bearings
Gene_French
First Name: Gene
Last Name: French
Board Member Since: 2014
Post by Gene_French » Fri Sep 11, 2020 10:16 am
this is my "home rebuilders special" ... i re-babbitt and linebore the mainbearings in your COMPLETLY disassembled Model T motor block ... this is for standard configuration mainbearings , crankshafts and caps only ... the customer is responsible for determining the suitability of the motor block ,crankshaft , caps and bolts ... i recommend that the crankshaft be magna-flux checked , straightened and properly re-ground , and the block carefully inspected for defects ... i pour the bearings using a automotive grade high Tin babbitt , linebore mainbearings with laminated shin set inplace , machine cut side wells and oil grooves , face thrust and cut clearance radii ... price is $450 plus shipping or customer can drop off and pickup at my site in Nunn,Colorado 80648 ... always an optimist Gene French 970-581-2808
Gene_French
First Name: Gene
Last Name: French
Re: Re-Babbitting service , Model T main bearings
Post by Gene_French » Fri Sep 11, 2020 3:52 pm
Note: this is your DISASSEMBLED and CLEANED motor block ... always an optimist ...Gene French 970-581-2808
