Wanted: Original Brass Oil Cap For 1913 Ford Touring
GEmering
First Name: Gene
Last Name: Emering
Post by GEmering » Sat Sep 12, 2020 10:18 am
I would like to purchase an original 1913 brass oil cap in good condition.
Thank you,
Gene
Gene Emering
Newton, New Jersey
MTFCA Number: 121
MTFCI Number: 16310
Re: Wanted: Original Brass Oil Cap For 1913 Ford Touring
Post by Original Smith » Sat Sep 12, 2020 10:26 am
There are two styles of this cap. Learn what they are, and don't let someone sell you a reproduction! Good luck. Both styles say Made In USA under the Ford script.
Tbird
Last Name: Bird
Post by Tbird » Sat Sep 12, 2020 3:43 pm
Here’s what you need to look for
http://www.mtfca.com/discus/messages/50 ... 1446574786
The early caps with the Made In USA don’t show up very often, so if you see one grab it when you can
Adam
First Name: Adam
Last Name: Doleshal
MTFCA Number: 23809
MTFCI Number: 1
Post by Adam » Sat Sep 12, 2020 3:59 pm
FYI, I’ve found the “going rate” for a decent one is around $125-$150. I’ve seen them for more, but you can usually get one for that.
Tbird
Last Name: Bird
Post by Tbird » Sat Sep 12, 2020 4:47 pm
This is the style that would be correct for late 1912-early 14.
GEmering
First Name: Gene
Last Name: Emering
Post by GEmering » Sat Sep 12, 2020 5:06 pm
Thanks to everyone for all of the information.
I have a copy of the judging guidelines, so know what to look for.
Am I correct that none of the repros have the 'made In USA" stamped in them?
Gene
Gene Emering
Newton, New Jersey
GEmering
First Name: Gene
Last Name: Emering
Post by GEmering » Sat Sep 12, 2020 5:22 pm
Not 1913 but is this an original?
download/file.php?id=65477&mode=view
Gene Emering
Newton, New Jersey
Tbird
Last Name: Bird
Post by Tbird » Sat Sep 12, 2020 5:28 pm
Correct on the repos not having Made in USA. I searched for mine for 6 years and gave up then 1 finally popped up on eBay. Can’t say if what you have there is original or not.
GEmering
First Name: Gene
Last Name: Emering
Post by GEmering » Sat Sep 12, 2020 5:31 pm
Also, I have this steel one currently on the car.
1915 vintage?
I would trade or sell this towards one that is correct for ‘13.
What is it worth?
Gene Emering
Newton, New Jersey
Fire_chief
First Name: Charlie
Last Name: Gagel
MTFCA Number: 8377
MTFCI Number: 22437
Post by Fire_chief » Sat Sep 12, 2020 6:31 pm
I believe that is for a 16
