Want To Buy: Amethyst H Lenses
Burger in Spokane
First Name: Brent
Last Name: Burger
Board Member Since: 2014
Post by Burger in Spokane » Mon Sep 14, 2020 1:24 am
Looking to make an extra pair (and spares ?) for my truck in a color like shown.
Happy to pay cash. Have clear and lighter pinks to trade, if you are trying to
make matching pairs. Thanks.
Burger in Spokane
First Name: Brent
Last Name: Burger
Re: Want To Buy: Amethyst H Lenses
Post by Burger in Spokane » Fri Sep 18, 2020 1:25 am
No one has some of these laying around ?
Jonah D'Avella
First Name: Jonah
Last Name: D'Avella
Post by Jonah D'Avella » Sun Sep 20, 2020 9:06 pm
I have got one, were they original to the car?
F: first
O: on
R: race
D: day
Burger in Spokane
First Name: Brent
Last Name: Burger
Post by Burger in Spokane » Mon Sep 21, 2020 1:01 am
The "H" lens became the standard around 1920 (?) and was used through the
end in 1927. The ones that will turn amethyst seem to show up on the 26-27
vehicles most often. Not sure if that is an accurate suggestion that a late
production run of lenses had manganese in the glass batch, or if it was simply
an intermittent thing. Most "H" lenses are dead clear. Some have enough
manganese in the glass to just turn a pink. Others can get quite dark purple.
Jonah D'Avella
First Name: Jonah
Last Name: D'Avella
Post by Jonah D'Avella » Mon Sep 21, 2020 6:46 am
On my 26 touring, I have one clear lens and one amthest.
F: first
O: on
R: race
D: day
Burger in Spokane
First Name: Brent
Last Name: Burger
Post by Burger in Spokane » Mon Sep 21, 2020 10:17 am
That seems to fit the pattern I have seen. Would you like to sell your
amethyst one ? I can send a clear to give you a match. If this is of interest,
take a photo of the lens in question, as I am trying to make a match as
well. Thanks.
Jonah D'Avella
First Name: Jonah
Last Name: D'Avella
Post by Jonah D'Avella » Mon Sep 21, 2020 2:52 pm
Here is a picture.
F: first
O: on
R: race
D: day
Burger in Spokane
First Name: Brent
Last Name: Burger
Post by Burger in Spokane » Mon Sep 21, 2020 10:34 pm
Hard to tell the color from that pic. Best to take it loose and lay it on white paper.
Jonah D'Avella
First Name: Jonah
Last Name: D'Avella
Post by Jonah D'Avella » Tue Sep 22, 2020 12:14 pm
It seems like they are riveted in
F: first
O: on
R: race
D: day
Last Name: Gregush
Post by Mark Gregush » Tue Sep 22, 2020 12:29 pm
After you take the rim off, you just bend the tabs on a couple of the clips back and lens will come out. Or just flip it over and take from the back side.
1921 Huckster
Last Name: Seth
Post by perry kete » Tue Sep 22, 2020 12:30 pm
They are not riveted in the light ring pushes in and turns to release the lens and service the bulbs.
Chris Haynes
First Name: Chris
Last Name: Haynes
Post by Chris Haynes » Tue Sep 22, 2020 9:45 pm
I have been doing that to one of mine for over a year trying to remove it. Even saturating with Kroil doesn't help. :-(
MTFCA Number: 14972
MTFCI Number: 15411
Post by RajoRacer » Wed Sep 23, 2020 11:30 am
I've had good luck putting the light on a rubber mat on the floor and using my body weight to push in & twist.
Jonah D'Avella
First Name: Jonah
Last Name: D'Avella
Post by Jonah D'Avella » Wed Sep 23, 2020 12:03 pm
I will try that
F: first
O: on
R: race
D: day
Burger in Spokane
First Name: Brent
Last Name: Burger
Post by Burger in Spokane » Thu Sep 24, 2020 2:09 am
I was shown a dandy period tool that is in the shape of an "H". The center bar
perfectly holds the legs at a spacing just smaller than the outside dimension of
the ring. Two of the same end of the legs have slots in them, that fit over the
rivets. The non-slotted ends are where the users puts some muscle to the whole
affair to remove stubborn rings. I can post a pic if anyone is interested.
Post by TRDxB2 » Thu Sep 24, 2020 10:11 am
I have found that to remove the headlight rim you must first loosen the rim from the headlight bucket. There is a spring, T-6586X, as shown in the diagram, that often gets stuck to the reflector through rust and/or dirt. So the first step is to break that bond loose by kneading -squeezing the rim against the headlight bucket (palm on the rim and fingers on the bucket). Its necessary to do this around the entire rim until you can fell the rim compress. If the headlight is mounted on the car the you need to rotate the rim counter clockwise while compressing it against the bucket. If the headlight is off the car its easier to have a person hold the headlight bucket while compressing and rotating. It is also possible to place it on a no-skid surface , rim down, and push down and rotate the bucket counter-clockwise. The u-shaped tool only works when the rim is able to be compressed all the way around.
