Winfield S & SR carburetor parts **NEW**
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Fri Sep 18, 2020 9:37 pm
Brand new Winfield model S & SR carburetor choke horns, V band clamps, and choke brackets now available. All components are near exact reproductions of the original designs and will interchange with original components. Current available size is AA-B only. Other sizes to be available depending upon demand.
Choke horns are machined from solid aluminum and are ready to install. Completely assembled with new stainless steel choke butterfly and brass pivot shaft. $250 ea.
V band clamps are machined from solid stainless steel and are ready to install, complete with stainless steel hardware. $90 ea.
Choke brackets are stamped from stainless steel and are ready to install, complete with stainless steel mounting screws and clamp screw/nut. $40 ea.
First Name: Henry
Last Name: Lee
MTFCA Number: 479
Re: Winfield S & SR carburetor parts **NEW**
Post by Henry K. Lee » Fri Sep 18, 2020 9:42 pm
Very nice work Kevin!
Hank
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Fri Sep 18, 2020 9:42 pm
Contact info...
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Sun Sep 27, 2020 2:34 pm
Bump......
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Fri Oct 16, 2020 10:30 pm
Been working on a new float bowl... pics coming soon👍
elliott1936
Last Name: Elliott
MTFCA Number: 9495
Post by elliott1936 » Sat Oct 17, 2020 12:16 pm
Kevin:
I would like to purchase a clamp for the air horn. Tom Elliott 503-644-9374
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Mon Oct 19, 2020 11:50 pm
Thank you Tom! It on its way 👍
