Winfield S & SR carburetor parts **NEW**
Posted: Fri Sep 18, 2020 9:37 pm
by Kevin Pharis
Brand new Winfield model S & SR carburetor choke horns, V band clamps, and choke brackets now available. All components are near exact reproductions of the original designs and will interchange with original components. Current available size is AA-B only. Other sizes to be available depending upon demand.
Choke horns are machined from solid aluminum and are ready to install. Completely assembled with new stainless steel choke butterfly and brass pivot shaft. $250 ea.
V band clamps are machined from solid stainless steel and are ready to install, complete with stainless steel hardware. $90 ea.
Choke brackets are stamped from stainless steel and are ready to install, complete with stainless steel mounting screws and clamp screw/nut. $40 ea.
Re: Winfield S & SR carburetor parts **NEW**
Posted: Fri Sep 18, 2020 9:42 pm
by Henry K. Lee
Very nice work Kevin!
Hank
by Kevin Pharis
Posted: Sun Sep 27, 2020 2:34 pm
by Kevin Pharis
Bump......
Posted: Fri Oct 16, 2020 10:30 pm
by Kevin Pharis
Been working on a new float bowl... pics coming soon
Posted: Sat Oct 17, 2020 12:16 pm
by elliott1936
Kevin:
I would like to purchase a clamp for the air horn. Tom Elliott 503-644-9374
Posted: Mon Oct 19, 2020 11:50 pm
by Kevin Pharis
Thank you Tom! It on its way
Posted: Fri Oct 30, 2020 8:21 pm
by Kevin Pharis
Bump......
Posted: Tue Dec 01, 2020 1:43 am
by Kevin Pharis
Have been continuing toward my goal of building complete S-B downdrafts from scratch. So far the choke horn, V band clamp, and float bowl are done. The float bowl cover and float ball for both S and SR carbs are next.
Posted: Fri Dec 04, 2020 8:11 am
by dmdeaton
Wow!!!!!!!
Here is my old beater
Posted: Fri Dec 04, 2020 12:50 pm
by John bevardos
How well do these perform . I have a couple at home and haven't tried them .......yet .
John
Posted: Fri Dec 04, 2020 10:31 pm
by Kevin Pharis
John bevardos wrote: βFri Dec 04, 2020 12:50 pm
Iβm a bit biased... so I will hold my comments
. But I will say that rather than arguing over which factory produced carburetor worked best, the Winfield S/SR and similar designed carbs were normal equipment at Indy throughout the 30βs
Posted: Thu Jan 28, 2021 10:16 pm
by Kevin Pharis
Iβm still workin toward complete carbs, and so have straight and elbow choke horns, V band clamps, choke brackets, and now fuel inlet blocks in stock. Will also have S and SR float balls, and modern needle and seat float bowl covers available soon...
Posted: Fri Jan 29, 2021 12:07 am
by Susanne
When you get it PLEASE let us know, I have a B sized BB body that is perfect but for the manifold flange on top that has a radial crack 60% around it...it makes me sick, as I want so bad to rin this carb, but I know, lest I build a brace to hold it up, it will fail...
What you are doing is a true GIFT to the hobby... I just wanted to say that... along with our heartfelt thanks!!!
Posted: Fri Aug 27, 2021 11:56 pm
by Kevin Pharis
Continuing to make progress, now have new float bowl covers complete with ball detents, new float levers, and Viton tipped float needles
And hereβs a pic of progress so far, still have some cosmetic work to do to the exterior of the throttle barrel, but otherwise is internally finished
Posted: Sun Aug 25, 2024 6:33 pm
by Kevin Pharis
Guess itβs been a while since the last bump. Have been continually adding new parts and accessories for Model S and SR series carbs. All interchangeable with original components, from gaskets to throttle barrels.
V band clamps in all sizes
Compensator and accelerator pump tools
Brass floats
