Does anyone have a factory print for the rear axle shaft, that could be shared/
Richard
rwill1914 at aol.com
Rear Axle Print
- First Name: Adam
- Last Name: Doleshal
- MTFCA Number: 23809
- MTFCI Number: 1
Re: Rear Axle Print
What dimension do you need?
Topic author - Posts: 247
- Last Name: Williamson
- * REQUIRED* Type and Year of Model Ts owned: 1913
Re: Rear Axle Print
all dimensions
Re: Rear Axle Print
There are several sources of generic and partial dimensions for the axle shaft that have been published here but nothing complete or toleranced. If you need all dimensions with tolerances, you will want to contact the Benson Library at THF and buy a copy of the drawing.
NH Full Flow Float Valves
Re: Rear Axle Print
That's what I've done
