Armature tester sold
CTLeonard
Last Name: Leonard
Post by CTLeonard » Mon Nov 02, 2020 10:09 am
I have no idea about it make me an offer
Pops
First Name: David
Last Name: Houston
* REQUIRED* Type and Year of Model Ts owned: 13,14,19,21,&etc
MTFCA Number: 32227
MTFCI Number: 23901
Re: Armature tester
Post by Pops » Mon Nov 02, 2020 9:33 pm
Hello C-T L: Did you plug it in and /or test it ? Very simple just put an armature on it and see if it growls and bites the hacksaw blade.
Easy
POPS
TrashMan
First Name: Chuck
Last Name: Griffin
MTFCA Number: 31570
Re: Armature tester
Post by TrashMan » Tue Nov 03, 2020 6:27 pm
I will give ya 12 bucks.
First Name: Henry
Last Name: Lee
MTFCA Number: 479
Re: Armature tester
Post by Henry K. Lee » Tue Nov 03, 2020 6:44 pm
Thats an original Blue Point! They work very well. Put a ground on it to prevent excitement!
MTFCA Number: 14972
MTFCI Number: 15411
Re: Armature tester
Post by RajoRacer » Tue Nov 03, 2020 7:17 pm
I've been using mine for over 20 years - where would you wire in a ground, Hank ?
First Name: Henry
Last Name: Lee
MTFCA Number: 479
Re: Armature tester
Post by Henry K. Lee » Tue Nov 03, 2020 7:56 pm
On the base housing. Mine bit me twice so have it on a GFCI receptacle and three prongs.
david_dewey
First Name: David
Last Name: Dewey
MTFCI Number: 19936
Re: Armature tester
Post by david_dewey » Wed Nov 04, 2020 1:59 am
Sounds like an insulation problem The "base" should be electrically issolated. Not that putting in a grounded wire cord isn't a bad idea though.
T'ake care,
David Dewey
First Name: Henry
Last Name: Lee
MTFCA Number: 479
Re: Armature tester
Post by Henry K. Lee » Wed Nov 04, 2020 6:49 am
David the test leads are hot with the light bulb socket. When it is a hot and humid day here in the south (down yonder), not a good Idea to test with old non OSHA approved equipment! LOL! No I do not have Parkinson's just shock therapy.
MTFCA Number: 14972
MTFCI Number: 15411
Re: Armature tester sold
Post by RajoRacer » Wed Nov 04, 2020 9:54 am
Thanks Hank !
david_dewey
First Name: David
Last Name: Dewey
MTFCI Number: 19936
Post by david_dewey » Fri Nov 06, 2020 1:11 am
Yes, you do have to be careful with the test leads!
T'ake care,
David Dewey
