NOS Early Rear Crossmember FS
Topic author - Posts: 4111
- Last Name: Hatch
- MTFCA Number: 49974
Here is something you do not see everyday. This is a NOS Rear Crossmember for Pre 13 frame. You can repair your early frame or make one out of an 14/15 frame. This came in some parts I brought and I was going to keep it but here it is for sale. $500.00 + shipping. Email me at address in pictures. I can get you more pictures if needed. Thanks Dan
- First Name: Herb
- Last Name: Iffrig
Re: NOS Early Rear Crossmember FS
Off the top of my head, is P&B Parish and Bingham?
- Last Name: Hatch
Back to the top
- Last Name: Hatch
Back to the top
- Last Name: Hatch
Back to the top
- First Name: R.V.
- Last Name: Anderson
Yep; Parrish & Bingham. It's the real deal.
- Last Name: Hatch
Thanks RV. It was in a batch of parts I bought than contained many early NOS parts. About 12 front over axle wishbones. Only one problem, someone stood them on the ground with the studs in the dirt. All had the studs all but rusted off! Oh well, win some lose some. Dan
- First Name: R.V.
I have repaired a lot of early rear wishbones by cutting off the worn and beat-up threaded sections and welding new studs in place. That could probably be done with the fronts as well.
- Last Name: Hatch
back to the top
- Last Name: Hatch
Back to the top
- Last Name: Hatch
Back to the top
- Last Name: Hatch
Back to the top
- Last Name: Hatch
Back to the top
- Last Name: Hatch
Back to the top
- Last Name: Hatch
Back to the top
- Last Name: Hatch
Back to the top
- Last Name: Hatch
Back to the top
- Last Name: Hatch
Back to the top
- Last Name: Hatch
Back to the top
- Last Name: Hatch
Back to the top one more time then back to the shelf
