WTB: Distributor cap for Bosch T-448
Topic author - Posts: 205
- First Name: Jeffrey
- Last Name: Hausey
- MTFCA Number: 51193
Looking to buy distributor cap/s for American Bosch, part # 65942
- First Name: Tom
- Last Name: Elliott
- * REQUIRED* Type and Year of Model Ts owned: 1921 Speedster 1927 speedster
- MTFCA Number: 9495
- MTFCI Number: 9495
Re: WTB: Distributor cap for Bosch T-448
I have a dist. cap that I'm not sure what it will work on. I can send you pictures of the cap and you can decide if it is something that you can use.
Tom twoelliott@msn.com
- Last Name: Hausey
Inside cap is marked 65942., 66880.
You may just need a carbon plunger like LL-47. Not sure if this parts lists applies but might help with a solution. Found another person looking for a Bosch #66880 "Want to buy for a 1911 Knox 4 cyl model R, Bosch #66880 distributor cap **Gilfillin #LL-55; Guaranteed #BI-5; KEM #1600." Looks like some cross reference ones are indicated. A LL- 55 cap is used on a American Bosch 600 distributor
- Last Name: Hausey
Thank you Frank.
A correction to the cross reference its GILFILLAN not GILFILLIN their catalogue page is the same as the SUREHIT. I'm looking for parts too since I have an American Bosch 600 distributor and would like some spare parts. If someone has some old parts books it may be possible to get some replacement from different manufacturers
- MTFCA Number: 14972
- MTFCI Number: 15411
There's a fellow in the midwest (I believe) that has NOS ignition parts - he's answered a request for Bosch parts on this Forum a while back.
- First Name: Tom
- Last Name: VanMeeteren
- * REQUIRED* Type and Year of Model Ts owned: 1911 touring 1923 touring
I am the "fellow in the midwest" and I do have a large inventory of NOS ignition parts for most makes and models from 1910 to 1960. I have Bosch rotors and point sets but do not have caps for sale at this time. I have contact with two other people with similar inventories here in the US and neither one of them have the 4 cylinder Bosch cap in stock at this time either. I do have one NOS Bosch cap that I am holding back for a pattern.
I have been thinking about reproducing them but would probably need about 40 - 50 people step up and agree to purchase them. Quantity will be a large factor in this project as the more we have made, the less cost per unit. You may email me with your thoughts and questions tsvanmeet@gmail.com
- Last Name: Hausey
I would buy 6.
Thanks for interjecting Tom !
I be good for 2. 3 depending on price. The American Bosch 600 has centrifugal advance not sure about the other models.
- Last Name: Hausey
Bump for the holidays.
- MTFCA Number: 52564
Maybe posting a little more information on what distributor you need the cap(s) for would help, besides just a part number. There are about 3 styles of Bosch clip on all which should used the same cap, rotor and points, the front plate that is different and then the other non Ford applications. Not everyone will know the part number for the cap but may know that the cap they have fits X.
1920 Dodge touring
1920 Dodge touring
- Last Name: Hausey
Great idea. The front plate.
You might also do a title change to something like "Wanted T-448 distributor cap for Bosch front plate distributor". You can click on the pencil and edit the title. It will only change the first/main title that people see but should help too.
1920 Dodge touring
1920 Dodge touring
