One man top back 3 sockets
Topic author - Posts: 486
- First Name: Keith
- Last Name: Townsend
- MTFCA Number: 14778
- MTFCI Number: 16305
This touring car one-man top was cut down for a single seat vehicle. Use the same way, or add on front socket assembly for '23-'25 touring. Rust-free! $100 + the ride.
- First Name: Jonah
- Last Name: D'Avella
Re: One man top back 3 sockets
Would they be adaptable for a 26?
- First Name: Jonah
If so, i am interested.
- First Name: Jonah
Does anyone know if these can be adapted to fit a 26?
- Last Name: Humble
Jonah, no, they are not really adaptable for 26-27. You can spot the 26-27 irons a mile away by the curve at the bottom. If you do not see the curve they are not the right ones. Also my experience at buying bits and pieces of top irons is a slow and expensive process that seldom turns out as good and affordable as buying a complete set.
- First Name: Jonah
Ok, thanks!
- First Name: Keith
Thanks, Jeff. I don't know enough about the '26-'27 to answer!
