early perch
Topic author - Posts: 58
- First Name: Rich
- Last Name: Huggins
- MTFCA Number: 50661
early perch
wtb early front perch 14-15 2 hole in good shape
- MTFCA Number: 14972
- MTFCI Number: 15411
Re: early perch
I'll take a look Rich - I might have an "orphan".
- First Name: DAN
- Last Name: MCEACHERN
Re: early perch
Ya need to tell folks which side you need- left and right are different.
- First Name: Rich
Re: early perch
Hi well i need a right but i think i could make a left work a little welding grinding and a little filing maybe installing a bushing don't really know yet
Re: early perch
No you can not make a left work with a little grinding and welding! If someone was killed or badly hurt because of wrongly made part, esp something the had to do with steering or car was sold later with something like that, I would not want to be in your shoes. The angle of the axle is forged into the perch. To be sure, you need the right hand perch as seen from when sitting in the car?
1920 Dodge touring
1920 Dodge touring
- First Name: Rich
Re: early perch
Gee Mark the left perch will go in the right and the right perch will go in the left can you figure that one out! The lower hole in the perch is for the Radis rod and i still have the one on the rod on the bottom . Installing dual Radis rods that's why the 2 hole perches one at the top for the spring arm and one at the bottom for the radis rod will support the front keeping the front end straight and the radis rods are attached to the frame . I will check caster and camber will align front to rear check and that the car track right in a pervious post you ask why i needed used bearing and races. Two mock up the front hubs to accept disc brakes installing front and rear disc brakes so the only one i would kill would be me its been a life
- First Name: Charles
- Last Name: Jenkins
- MTFCA Number: 28066
Re: early perch
I have a friend that had some N O S ones I will check if he still has them I will post it
Re: early perch
I didn't ask why you needed bearings, in fact this is my only post and what I posted before you said what you were doing at the very end of the post;Rich Huggins wrote: ↑Tue Jan 05, 2021 7:25 pmGee Mark the left perch will go in the right and the right perch will go in the left can you figure that one out! The lower hole in the perch is for the Radis rod and i still have the one on the rod on the bottom . Installing dual Radis rods that's why the 2 hole perches one at the top for the spring arm and one at the bottom for the radis rod will support the front keeping the front end straight and the radis rods are attached to the frame . I will check caster and camber will align front to rear check and that the car track right in a pervious post you ask why i needed used bearing and races. Two mock up the front hubs to accept disc brakes installing front and rear disc brakes so the only one i would kill would be me its been a life
Re: used bearing races
Post by Mark Gregush » Mon Dec 21, 2020 10:01 am
If you can wait on the shipping, Rock Auto has some good prices. Depending on what warehouse they come out of, USPS shipping is running behind. Depending on what part of the country they are being shipped to, Snyder's and Lang's could be in the same boat, re shipping.
If this is for the mock up, making up a perch would be fine, if not my OP stands and as it is, you have people that might have the correct part.
1920 Dodge touring
1920 Dodge touring
Re: early perch
My friend thinks he has some N O S ones if interested I can give you his contact information no PMS
Re: early perch
Sorry Rich - no orphans !
