Ring and Pinion set #1
tselliott
Last Name: Elliott
Post by tselliott » Fri Nov 20, 2020 2:01 am
Set #1, Ford gears.
Pinion gear is as perfect as one would hope to find. Bore and keyway look great, no chipped teeth or pitting. Ring gear has no pitting or chipped teeth although 5 of the teeth show some wear across the tops.
I tried to show the best I could in the pictures.
I don’t know for sure if they were actually a set that were run together. I got these in a pile of parts I bought and they were not wired together. They have been bead blasted to remove light surface rust.
$175 plus shipping.
Scott Elliott
971-5O6-94O2
Les Schubert
First Name: Les
Last Name: Schubert
Re: Ring and Pinion set #1
Post by Les Schubert » Fri Nov 20, 2020 11:09 am
I would run them,especially if money was tight
MTFCA Number: 121
MTFCI Number: 16310
Post by Original Smith » Fri Nov 20, 2020 11:35 am
Scott, I would have posted this on the classifieds! I'd use them.
Pep C Strebeck
First Name: Joseph
Last Name: M
MTFCA Number: 0
Post by Pep C Strebeck » Fri Nov 20, 2020 11:40 am
I can not find the previous post on the subject, but I did save a copy of the pictures that were included in the original post. This was from the May, 1923 Ford Service Bulletin, published by the Ford Motor Company of Canada. Does the ring gear have the same "punch" mark as the pinion gear does?
I found the original post, here is the link:
http://www.mtfca.com/discus/messages/82 ... 1545965436
LOOKING FOR A LUFKIN Model 1671A Center Punch.
Post by Mark Gregush » Fri Nov 20, 2020 11:58 am
I have been corrected. Thank you.
1921 Huckster
MTFCA Number: 14972
MTFCI Number: 15411
Post by RajoRacer » Fri Nov 20, 2020 12:19 pm
I disagree Mark - it clearly states in the above posted Service Bulletin excerpt - you are referring the a Brinell test.
Adam
First Name: Adam
Last Name: Doleshal
MTFCA Number: 23809
MTFCI Number: 1
Post by Adam » Fri Nov 20, 2020 12:24 pm
A punch mark like that is probably not from a hardness test. Generally if a part like that is hardness tested, then only a sample (one part or a few parts) from each batch of heat treating gets tested, not every part.
The mark that a diamond penetrator makes for a hardness test on a gear or shaft would look sort of like a “pin-prick”.
tselliott
Last Name: Elliott
Post by tselliott » Sat Nov 21, 2020 10:40 pm
The ring gear has that same indent that the pinion gear has
Last Name: VanOoteghem
Post by Jerry VanOoteghem » Sun Nov 22, 2020 10:59 am
The diamond penetrator that makes the "pin-prick" mark is for Rockwell hardness tests. The Brinell test uses a ball indentor and leaves a mark as shown on the backside of the pinion, in the first set of photos.
Kirby
First Name: Kirby
Last Name: Gilmore
MTFCA Number: 24951
Post by Kirby » Thu Nov 26, 2020 11:07 am
still for sale?
tselliott
Last Name: Elliott
Post by tselliott » Thu Nov 26, 2020 2:44 pm
Yes it is.
