Re-babbitted main bearing caps,laminated shim set
Topic author - Posts: 849
- First Name: Gene
- Last Name: French
- MTFCA Number: 15614
- Board Member Since: 2014
For sale : Rebabbitted Model T main bearing sets , laminated shim set and timesaver lapping compound ... re-babbitted using tin base automotive high speed babbitt (SAE#2 Government Genuine alloy )... will supply caps bored to Standard diameter or customer specified dimension ... price of $145.00 includes postage in lower 48 states ... actual postage outside this area or INTERNATIONAL ... Gene French 49519 cr23 Nunn,Co. 80648 phone 970-581-2808
- First Name: Gene
- Last Name: French
Re: Re-babbitted main bearing caps,laminated shim set
to the top again , thanks MTFCA
- MTFCA Number: 121
- MTFCI Number: 16310
What is the thickness of each shim?
- First Name: Gene
- Last Name: French
Larry:
i will check to be certain , but the laminated shim is .016" thick ... being 8 .002 shims total ... in theory a single .002" shim is removed from 1 side of the cap to effect a .001" adjustment ... if a smaller increment is needed a person may lap the caps ... i will lap with wet 180 sandpaper on a precision surface ( lapping block) ... hope this answers your question ... the shims supplied are a standard production product sold by Snyders Antique Auto and probably most other parts suppliers ...always an optimist ...Gene French
- First Name: Gene
- Last Name: French
- First Name: Gene
- Last Name: French
to the top again ... thanks MTFCA
