Wtb patch panel for a 23 touring CANADIAN
Topic author - Posts: 64
- First Name: Thomas
- Last Name: Black
- * REQUIRED* Type and Year of Model Ts owned: 1923 touring
Hello all looking to buy or find someone who can make me a rear patch panel for a 23 touring. Thanks
- First Name: Ken
- Last Name: Buhler
- MTFCA Number: 49471
- Board Member Since: 2012
Re: Wtb patch panel for a 23 touring CANADIAN
Try to find a local auto body person who knows how to form sheet metal, through a near or local car club.
That is a significant but not large repair. It looks like a nice car to start with. You are fortunate that it is not "the rot". First, if the fabric is out, use a thin hacksaw blade or other tool and use air pressure to clean between steel and wood every spot you can reach in your car. Don't start your restoration with finishing the surface. And certainly don't start painting until the ENTIRE body has been level, fitted, and working. Form the patch first and fit it carefully over the existing body. Trace the patch, then micro thin blade cut out the sheet metal with a Dremel type cutter or other. Final fit the patch to the body shape. Then,,,, weld.
You can email me for some pictures of what I did with a roadster if you wish.
Ken Buhler
Ken Buhler
Work honestly
Stay true to your word
Get the job done right
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
I do panel making, send me measurements via email.
Glad to Help,
Glad to Help,
- First Name: Ken
- Last Name: Buhler
You just found your best connection. Look at Hanks car.
Ken
Ken
Work honestly
