Red rubber gas line
Topic author - Posts: 3284
- MTFCA Number: 121
- MTFCI Number: 16310
Red rubber gas line
WTB, some red gas light cloth covered hose that was made by Ron Gocek several years ago. This was either 7/16 or 1/2 OD, and fits through the radiator holes. I need enough to go from the carbide generator to the frame mounted gas line on a 1913.
Re: Red rubber gas line
Awhile back someone got some from S&J parts but it may have been the last of it
- Last Name: Gresh
- MTFCI Number: 15762
I have a couple pieces of the 7/16 left from my 1913.
If you think one of these is long enough or you could use the pair of them. Let me know and my wife will get them out in the mail to You.
Larry
- Last Name: Williams
- * REQUIRED* Type and Year of Model Ts owned: 1924 TT, 1923 Touring, 1927 Tudor, 1915 Roadster
This is available at Harbor Freight, just need to use some light solvent to remove inked on lettering that comes off easily and cut off the ends. Looks exactly like the original. Cost is $6.50 Here's the link: https://www.harborfreight.com/3-8-eight ... 98943.html
- First Name: Benjamin
- Last Name: Eckstein
- * REQUIRED* Type and Year of Model Ts owned: 24 Roadster Pickup, 13 Runabout, 13 Touring, 14 Light Delivery, 15 Speedster
- Board Member Since: 2012
Original Smith wrote: ↑Wed Dec 09, 2020 11:03 amWTB, some red gas light cloth covered hose that was made by Ron Gocek several years ago. This was either 7/16 or 1/2 OD, and fits through the radiator holes. I need enough to go from the carbide generator to the frame mounted gas line on a 1913.
Larry,
I never could find the cloth covered either, but I did find the (possibly color correct) red gum rubber tubing from Thomas Scientific part # 9532S30. 7/16" OD x 1/4" ID 3/32" wall thickness
I found it on Amazon and bought it there. Its still available for 14 dollars for 10 feet.
https://www.amazon.com/Tubing-4X7-16X3- ... B01MRCL2AA
Benji
