Rear Axle Print
RichardW
Last Name: Williamson
Rear Axle Print
Post by RichardW » Thu Feb 28, 2019 11:43 am
Does anyone have a factory print for the rear axle shaft, that could be shared/
Richard
rwill1914 at aol.com
Adam
First Name: Adam
Last Name: Doleshal
MTFCA Number: 23809
MTFCI Number: 1
Re: Rear Axle Print
Post by Adam » Thu Feb 28, 2019 12:17 pm
What dimension do you need?
RichardW
Re: Rear Axle Print
Post by RichardW » Thu Feb 28, 2019 2:03 pm
all dimensions
Re: Rear Axle Print
Post by Scott_Conger » Thu Feb 28, 2019 4:56 pm
There are several sources of generic and partial dimensions for the axle shaft that have been published here but nothing complete or toleranced. If you need all dimensions with tolerances, you will want to contact the Benson Library at THF and buy a copy of the drawing.
RichardW
Re: Rear Axle Print
Post by RichardW » Thu Feb 28, 2019 7:42 pm
That's what I've done
