FS 1916-20 Steel Hub Fan SOLD
Tbird
Last Name: Bird
Post by Tbird » Thu Dec 31, 2020 11:06 pm
I have a steel hub fan for sale. It is in very good useable condition. Blades are in great shape, rivets are tight, and fan spins great. Greased up and ready to go. $100 plus shipping.
mikebird@lifeattheridge.net or 574-584-6744
Tbird
Last Name: Bird
Re: FS 1916-20 Steel Hub Fan $100
Post by Tbird » Tue Jan 05, 2021 8:33 am
Price drop
Tbird
Last Name: Bird
Re: FS 1916-20 Steel Hub Fan $80
Post by Tbird » Tue Jan 12, 2021 8:37 pm
Price drop again $80 plus shipping
Jonah D'Avella
First Name: Jonah
Last Name: D'Avella
Post by Jonah D'Avella » Tue Jan 12, 2021 8:46 pm
Is it able to fit a 27?
F: first F: find
O: on O: oil
R: race R: revive
D: day D: drive
Jonahdavella@gmail.com
Tbird
Last Name: Bird
Post by Tbird » Tue Jan 12, 2021 9:00 pm
Jonah,
I think the hub is different for 27. I’m not to sure as if a earlier fan can be used and if other things would have to be changed out in order to make it work. Perhaps someone else can chime in on this.
MTFCA Number: 14972
MTFCI Number: 15411
Post by RajoRacer » Tue Jan 12, 2021 9:57 pm
Jonah - a nice NEW repro fan is available for your year T.
Post by Wayne Sheldon » Wed Jan 13, 2021 5:18 am
Jonah,
We-ell----, it would be possible to make one of these work on a 1927, but a lot of trouble for something so wrong and costing more than the right thing would.
There are a couple variations to the 1926/'27 fan assemblies. One of which is a longer reach shaft and hub that does not work well with most available radiators. You should check with your advisors to determine what you have and what you need, either nearby you, or pictures on the general forum. If you do have the late long hub fan, you would be better off to replace it with the more common shorter reach fan hub. (The fan itself is the same.) I suspect you should be able to get the fan hub and maybe even mounting neck fairly cheap.
If I recall correctly, I may still have one of the long fan hubs. Nobody wants them.
Brent Mize
First Name: Brent
Last Name: Mize
MTFCA Number: 10000
Post by Brent Mize » Wed Jan 13, 2021 5:54 am
Mike,
I emailed you about the fan.
Thanks!
Last Name: Hatch
MTFCA Number: 49974
Post by Dan Hatch » Wed Jan 13, 2021 8:47 am
Longed fan hubs are for the 3 row radiator cores. No body wants either one of these. Dan
Tbird
Last Name: Bird
Post by Tbird » Wed Jan 13, 2021 12:29 pm
Sold to Brent. Thanks MTFCA!
