Rear porch & shackle set FS
Last Name: Wrenn
MTFCA Number: 30701
MTFCI Number: 24033
Post by TWrenn » Sat Jan 09, 2021 1:32 pm
Heres an excellent set of original shackles, with the correct style clamping plate. Typically for '17-'22 on the shackles, they can be used any year. The perches are basically early style up to '18 as no oiler holes, or you could drill your own in.
$160 for the whole set. New bushings. Fit nice and snug with these shackles. Threads are excellent. Now's the time to make that old sloppy rear suspension good as new and safe again. I do have the shackles listed separately elsewhere for $110 plus shipping. Ship should be $9 flat rate. PayPal please. But will accept check or M.O. pls call or text me at 419-217-5405
No PM's please. Thanks
Last Name: Wrenn
MTFCA Number: 30701
MTFCI Number: 24033
Re: Rear porch & shackle set FS
Post by TWrenn » Wed Jan 13, 2021 10:42 am
Back to the top in case someone is out there now getting ready to make their rear suspension safer.
Post by Allan » Wed Jan 13, 2021 3:54 pm
Tim, our Canadian sourced cars used two L shaped forgings for shackles up to around 1925. I know US production went to U shaped shackles earlier, but I do not know when. Your application window may/may not need adjusting.
Hope this helps.
