Accessory Stromberg choke control
Topic author - Posts: 3384
- Last Name: Morsher
I have these ready to ship. Tmorsher@icloud.com to reach me, PLEASE NO PMs or messages here. I may or may not do another batch in the late fall.THANKS! T
A couple of folks have changed their mind or not ready for one, so I do have several extra available right now. These new controls have a SS flat wound Bowden cable covered in black vinyl and will blend in better on a black steering column. Makes an accessory carb such as the Stromberg RF,OF,LF or others much easier to handle. These continue to be made in USA ( my shop) with all stainless steel fasteners, and come with the bracket to mount to a model T steering column. $165 postpaid to you door. -
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
Re: Accessory Stromberg choke control
Very nice product Tim, very happy with the two I received from you.
All the Best,
Hank
All the Best,
Hank
- First Name: Bill
- Last Name: Crosby
- * REQUIRED* Type and Year of Model Ts owned: 1916 Touring, 1920 Coupe, 1926 RPU, 1927 RPU, 25 speedster project
Tim, Could you post a picture of your choke control mounted on the steering column.
Bill
Bill
Thanks Hank, nice words coming from another blacksmith ! Bill, I’m attaching some photos. The LF instructions state about 10” from top of steering post. I’ve found about 4 phat phingers phrum the quadrant is in the ballpark. This gets you right above the horn wire tube, if you have one.
- Last Name: Stroud
- Board Member Since: 2011
I had one of Tim's choke controls and then sold it because I found an original. Let me tell you, there is almost no difference between the two, other than the cable, Tim, I think that coated cable was definately the way to go. Dave
1925 mostly original coupe.
I agree
this is a great product, faithfully reproduced.
NH Full Flow Float Valves
On some of the last of these I shipped, I’ve been supplying with a braided stainless steel choke wire instead of the solid. When I shipped them , I used a small ferrule crimped on the end to keep the wire from unwrapping. It’s really good wire and doesn’t seem to, but I did it anyway. I’ve wired a couple of ferrules to the end, so for most applications ( the OF ) just cut off the one I crimped , and use a new one if needed when you get it adjusted. I’ve attached a picture. On some applications, you may want two crimped, one on each side of the arm, such as the RF installation. I’m not much for written instructions to include, perhaps I should have, but if anyone needs help, just ask, tmorsher@icloud.com
- First Name: Danny
- Last Name: Deaton
Tim,
Probably in my haste like a kid at Christmas I may have thrown out my column mount. Can I purchase a spare?
