Aftermarket accessory for Model T Ford not adapted from some other car which usually puts the rim higher up and makes the situation even worse! 17" diameter for good leverage steering. Has clearance hole for horn button wire when accessory button is used in place of original acorn nut in the center. $425, domestic shipping $25.
SOLD IT THANKS TO MTFCA
Fatman accessory steering wheel SOLD
Topic author - Posts: 1509
- First Name: Layden
- Last Name: Butler
- First Name: Russ
- Last Name: Furstnow
- * REQUIRED* Type and Year of Model Ts owned: 1909 Touring, 1913 Touring, 1914 Runabout, 1915 Coupelet, 1916 Coupelet
- MTFCA Number: 28
- MTFCI Number: 10546
Re: Fatman accessory steering wheel F/S
Layden, That is a Bauer wheel...I have the same on on my '27 Coupe. Russ Furstnow
