Wanted: TT Rear Wheels
Topic author - Posts: 15
- First Name: Brett
- Last Name: Wiebold
Looking for one of a few options for getting the rear wheels on my '25 TT squared away. Looking for either a set of decent solid rubber rear wheels, or a set of 23" Hayes split rims/lock rings that aren't bent completely out of shape. May also be interested in complete rear wheels depending on the price.
- First Name: Tom
- Last Name: Strickling
- * REQUIRED* Type and Year of Model Ts owned: 11 Torpedo, 18 Touring, 21 TT Huckster, 24 snowmpbile Staude and Shaw tractor conversions, Model T powered sickel bar mower
Re: Wanted: TT Rear Wheels
23" Hayes are a split rim but do not use a lock ring. The tire mounts to the split rim which has lugs permanently attached to it. No extra piece.
Kelsey made a 23" TT rear wheel set up that used a spacer ring about the diameter of a pencil that goes between the split rim and the wheel fellow. You have removable clamps for these instead of a fixed lug.
20 rear TT wheels use that extra "snap ring" that holds the tire onto the rim I do not think that rim is split. 20" rims may be available new but are pricey
https://www.universaltire.com/vintage-r ... g-rim.html
“The trouble with retirement is that you never get a day off.” – Abe Lemons.
