Pile new parts are good old items as well
Posted: Sun Mar 03, 2019 3:11 pm
See pics lot sale ONLY spring cleaning $125 includes postage in 48 states
Always open to offers
13-14 dash shield
26/7 hood corners protectors
Set Starter cover screws fan screws
Timer spring and bolt
Brush cover starter/gen
Windshield center seal
Battery cables bat ground bat to switch
Hand brake trim heavy steel pre 15 style
21" rim liner
21" rim clamp
2 fellow plates H stamp
Rear spring bolt
Unknown body brackets
Benix drive and part
Used
Water outlet late style radiator caps window crank plates (2) pedal trim plates heavy steel late style front license plate mounts front rear
Round tank brackets flat trans door
Probably be more as I clean all good items
13-14 dash shield
21" rim liner
21" rim clamp
Rear spring bolt
Used
