Ac linkage
Topic author - Posts: 46
- First Name: Matthew
- Last Name: Cooper
Ac linkage
Wtb original ac brake linkage or a good copy
- * REQUIRED* Type and Year of Model Ts owned: 1925 cutdown PU, 1920 Dodge touring, 1948 F2 Ford flat head 6 pickup 3 speed
- MTFCA Number: 52564
Re: Ac linkage
Too be sure you know, the original AC setup was cable not rods.
1920 Dodge touring
1920 Dodge touring
- First Name: Nikolaus
- Last Name: Martin
- MTFCA Number: 32342
- MTFCI Number: 23512
Re: Ac linkage
Some original AC setups were rods, but most were cable. Somewhere I have images of an original AC rods setup ad. Yes, though, good to point out not to try too hard to find an original rod setup.
- First Name: Joseph
- Last Name: Amara
Re: Ac linkage
Matthew, I sent you a PM.
Joe
Joe
- First Name: DAN
- Last Name: MCEACHERN
Re: Ac linkage
The original A-C setup was a rod from the brake pedal clamp to a guide bracket on the drive shaft tube and then a cable loop thru a pulley to each rear wheel brake arm. The pulley acted as an equalizer. The brake arm on the band had a clamp that the cable made a loop through.
Re: Ac linkage
The 1926/27 AC's, might have used rods. I do not recall ever seeing any original small drum AC brakes that were not cable. There were other brands that could have been rod activated. AC is not a type it is a brand, just like Rocky Mtn is not a type it is a brand.
1920 Dodge touring
1920 Dodge touring
- Last Name: Martin
Re: Ac linkage
Here you go. I agree that cables are what you commonly see on originally ACs, though.
Re: Ac linkage
Thanks for posting the flyer.
1920 Dodge touring
1920 Dodge touring
