WTB 1915 correct oilers
Topic author - Posts: 178
- First Name: Brian
- Last Name: Dowell
- * REQUIRED* Type and Year of Model Ts owned: 14 Touring 26 Runnabout 19 Canadian Touring
- MTFCA Number: 52162
- MTFCI Number: 205
I would like to purchase the Oilers only.
Brian
Brian
Life is Good, be nice.
- MTFCA Number: 121
- MTFCI Number: 16310
Re: WTB 1915 correct oilers
Doesn't look like any original I've seen!
- Last Name: Lyons
- * REQUIRED* Type and Year of Model Ts owned: 1913 Touring, 1915 Touring, 1925 Coupe
- MTFCA Number: 10000
The Oilers pictured were never factory installed on any Model T. What you have there are Maxwell Oilers. If you would like to sell them, send me a PM.
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
Let me go and look in my part bins.
- MTFCA Number: 14972
- MTFCI Number: 15411
How many correct ones are you needing ?
If correct oilers are not similar to what are sold for early brass cars, I would appreciate seeing one. My '15 has all the man-hole covers, etc., and I am curious now about "correct" shackle oilers.
Please someone post pix.
thanks
thanks
NH Full Flow Float Valves
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
This is what I have, the first to contact me with a reasonable offer gets them all. you pay shipping. Some are brand new never installed.
All the Best,
Hank in Tin-A-See
All the Best,
Hank in Tin-A-See
- First Name: Antonio
- Last Name: Piery
- * REQUIRED* Type and Year of Model Ts owned: some very old cars
This is whats on my shackles, don't know if they are correct or not.
Yes, that is the correct style BUT originals were "patent dated".
Here's what original Winkley patent dated twist oilers look like ! Far left is generator, center is '12 - '17 front axle & shackle - right are larger non-spring assisted for '09 - '11 front axle - in the neighborhood. And no, not for sale - I don't have many left.
I may be wrong about this? But I "think" the early '15s used the style like Antonio P shows, with patent markings as Steve T says. I have read and "believe" that Ford switched to the manhole style about early to mid calendar year 1915. The early manhole style was only used for about three years ('15/'16/'17). A lot of the earlier style twist brass oilers were made without the patent markings, and are often found on brass era model Ts.
Wayne
I thought the man-hole cover was on the kingpin and tierod links, but not the shackles? So, if those Antonio is showing have a spring loaded cap and you're right, then I've really learned something today (which really isn't a surprise, I suppose!). My '15 has man-holes where I expect, and pat. date oilers on shackles. Again, assuming you're correct, I wonder when/why there was a cross-over?
- First Name: Brian
- Last Name: Dowell
- MTFCI Number: 205
I have been corrected. The ones I showed first photo are as James stated for a Maxwell.
Shackles never had "manhole" oilers - all were the brass twist type until the tin "flip-top" type arrived on scene.
Scott - your timer, if original aluminum or cast iron, would also have the "manhole" oiler.
Brian - there are nice repro brass twist oilers available from all the vendors.
Steve Tomaso
thank you! Things are as I thought they were, and now all is right with the world.
- MTFCA Number: 121
The oiler posted by Antonio is an old reproduction. The ones that Langs sells are the closest to an original I've seen.
