5/16 Nuts
Topic author - Posts: 3298
- MTFCA Number: 121
- MTFCI Number: 16310
5/16 Nuts
I want to buy a couple dozen 5/16-18 raven finished nuts chamfered on top, and washer face on bottom.
- First Name: Adam
- Last Name: Doleshal
- MTFCA Number: 23809
- MTFCI Number: 1
Re: 5/16 Nuts
Square? Hex? Hex size? How thick?
As fussy as you are Larry, you are leaving a lot of details out...
Here’s one that’s just about to be finished by a raven:
- First Name: Ken
- Last Name: Buhler
- MTFCA Number: 49471
- Board Member Since: 2012
Re: 5/16 Nuts
That is brilliant Adam. I really enjoy the humor shared on the forum.
Work honestly
Stay true to your word
Get the job done right
- MTFCA Number: 121
Re: 5/16 Nuts
Adam: You got me on that one, although I've yet to see a square nut with a washer face! The thickness would be just under 9/32" hex.
- First Name: Darren
- Last Name: Wallace
Re: 5/16 Nuts
Larry, They do exist! I've taken them off of antique and vintage machinery for years and save them for restoration use. Early Machinery/Machinist Handbooks even give dimensions for them. I don't know how conveniently available they are nowadays....
- First Name: Adam
- MTFCI Number: 1
Re: 5/16 Nuts
Depends on your terminology.
The one on the left has a washer face on the bottom by modern terms.
But all of these that have a chamfer on the top and are just flat on the bottom could be considered to have a “washer face” too.
Post a picture of exactly what you are after. I’ve got some decent used stuff, but nothing NOS with ravencote on it.
- First Name: Gary
- Last Name: Hagen
Re: 5/16 Nuts
Where can one have a raven finish done to their nuts?
- First Name: Brent
- Last Name: Mize
- * REQUIRED* Type and Year of Model Ts owned: 1913 Runabout 1927 Sport Touring
- MTFCA Number: 10000
Re: 5/16 Nuts
Gary,
You can do your own with a black oxide kit or gun bluing kit.
You will need a sealer or and oil finish when done. I’m sure Ford used oil, but that’s just a guess.
It’s very easy.
Brent
It’s very easy.
Brent
- MTFCA Number: 121
Re: 5/16 Nuts
Eastwood makes those kits. I've been using them for years. You have to clear coat them afterward.
- MTFCA Number: 14972
- MTFCI Number: 15411
Re: 5/16 Nuts
I have some of Otis' 5/16 nuts Larry - I'll dig them out and see if they "fit the bill".
- First Name: Chris
- Last Name: Rini
- * REQUIRED* Type and Year of Model Ts owned: 1923 roadster
Re: 5/16 Nuts
Have you checked Blacksmith Bolt? https://www.blacksmithbolt.com/store/c/41-Nuts.aspx
- First Name: Joseph
- Last Name: Andulics
- MTFCA Number: 9766
Re: 5/16 Nuts
Is this what you're looking for? Raven finish 5/16-18 nut with washer face. Across the flats is 9/16" thickness is 5/16". Yours if you want them.
- Last Name: Warren
Re: 5/16 Nuts
What wrench size?
Re: 5/16 Nuts
Safe to assume Larry has either found what he needed or doesn't need them anymore?
