Ford bendix puller. Sold
Topic author - Posts: 1287
- First Name: Mike
- Last Name: Leonard
- * REQUIRED* Type and Year of Model Ts owned: 6
25.00 plus shipping
- First Name: ROBERT
- Last Name: BERGSTADT
- MTFCA Number: 1575
Re: Ford bendix puller
I will take it, put it in my pile, Bob
- First Name: Art
- Last Name: Mirtes
- MTFCA Number: 32489
- MTFCI Number: 24068
Re: Ford bendix puller. Sold
I am not familiar with this puller and I didn't know one is required to remove the bendix on a model t starter. Could someone explain its use. Thanks. Art Mirtes
- First Name: Adam
- Last Name: Doleshal
- MTFCA Number: 23809
- MTFCI Number: 1
Art, Normally it should not be required. The bendix is supposed to slip on and off the starter shaft. The puller is needed when something isn’t quite right that causes the bendix to stick a bit. Usually this is due to burrs that have raised up around the keyway or the set screw or damage from broken parts.
I have one of those pullers. I’ve likely pulled well over 50 starters in the last 20 years and probably used the puller less than 10 times. Usually only on rusty bendixes or broken ones.
- First Name: Art
- Last Name: Mirtes
Adam, thanks for explaining the bendix puller. I have one like the one shown in the picture, but thought it was just a general use sort of thing.
this puller if for pulling the Bendix head, not the Bendix, handy tool, Bob
- First Name: Adam
- MTFCI Number: 1
Yes, Bob Is Correct ! However, the entire assembly (Bendix, spring, head) typically is referred to generically as “bendix”. That is exactly what I provide customers when I rebuild a bendix. Maybe I should have clarified that into a more elementary explanation?
Please note: When I was writing about “pulling the bendix”, I should have written it specifically to say “bendix head”.
Even if the puller is required, Once the bendix head is removed, the rest of the bendix generally can be pulled off by hand about 90% of the time, if it isn’t easily removed, then there is usually a visible burr that can be dressed and then the bendix can be removed. I don’t think I’ve ever needed any sort of puller to remove a bendix after the bendix head was removed.
The bendix head should be a slip fit on the starter shaft. I have verified that. I have copies of the Ford prints.
