FOUND! - Rayfield intake manifold for L2P, L2C, etc.
Post by Scott_Conger » Sat Feb 06, 2021 6:26 pm
This manifold has an offset to push the carb out toward the frame, and has a built-in bell-crank to operate the throttle.
Thank you for looking, and please send me an email if you think you can help.
Re: WTB - Rayfield intake manifold for L2P, L2C, etc.
Post by Scott_Conger » Mon Feb 08, 2021 11:13 am
I know one is out there
StanHowe
First Name: Stan
Last Name: Howe
MTFCA Number: 19133
Post by StanHowe » Tue Feb 09, 2021 11:16 am
I have one but it has the carburetor with it. Won't separate but the unit is for sale.
Post by Scott_Conger » Tue Feb 09, 2021 12:04 pm
Thanks Stan
I was pretty sure you had one, and was pretty sure it had a carb on it! Unfortunately, not in the market for a third one...just the manifold.
Stay warm...it is -8 here but at least has stopped snowing.
dobro1956
First Name: Donnie
Last Name: Brown
Post by dobro1956 » Tue Feb 09, 2021 1:32 pm
Scott, can you post a pic. I may have one.
Post by Scott_Conger » Tue Feb 09, 2021 1:45 pm
Sure Donnie
Just got permission from Stan Howe to use one of his pictures.
The intake swoops "out" sort of like an early "T" dogleg and has a built-in belcrank to actuate the throttle linkage. It also has a "slot" instead of a hole in the forward mounting position, since the bel-crank boss impeeds the instalation of a long enough bolt through just a hole (the slot is not a post-purchase modification...it is original). A picture of one of Stan's set ups is this:
Thank you Stan.
dobro1956
First Name: Donnie
Last Name: Brown
Post by dobro1956 » Wed Feb 10, 2021 3:48 am
Scott, my manifold is similar. It is dog legged like the one you show. But mine has a hole on both sides and a "stop" for something, where the bell crank is in Stan's photo. I think it was designed for a "choke or throttle" plate ??? . Ill try to remember to post a photo of it tomorrow. I think it could be made to work by installing something for a bell crank mount. It is solid brass and would look good with a brass carb.
dobro1956
First Name: Donnie
Last Name: Brown
Post by dobro1956 » Wed Feb 10, 2021 1:11 pm
Scott Here are some pictures of my manifold. Even if you are not interested, maybe someone can tell me what it fit and why a possible throttle/choke plate ??? where it is located.
dobro1956
First Name: Donnie
Last Name: Brown
Post by dobro1956 » Wed Feb 10, 2021 1:12 pm
Post by Scott_Conger » Wed Feb 10, 2021 2:24 pm
Donnie
now THAT is neat! What a lovely bit of casting that is!
purely speculation but I wonder if there was an apparatus which would reduce the cross section such that velocity would be increased to maintain vaporization of fuel while engine was cold, which would be opened fully when at normal temperature (??)
Your efforts and interest are greatly appreciated, but it's not something I could forsee using...though I AM looking forward to finding out what this thing is, as you are too. Who knows, I may be passing on some fabulous bit of racing history, but that has been the story of my life! My heart says "buy it", but my wallet says "you can't afford it". HAHA!
Post by Scott_Conger » Sat Feb 20, 2021 11:20 am
Back to the top
I know it is out there
Re: FOUND! - Rayfield intake manifold for L2P, L2C, etc.
Post by Scott_Conger » Sun Feb 21, 2021 6:06 pm
Classified Ads Work
thank you Hank and Jeff!
First Name: Henry
Last Name: Lee
MTFCA Number: 479
Post by Henry K. Lee » Sun Feb 21, 2021 6:16 pm
Anytime here Guys!
Playswithbrass
First Name: Peter
Last Name: McIntyre
Post by Playswithbrass » Mon Feb 22, 2021 6:55 pm
Intake for a Stromberg carb that does not have a throttle plate. Cheers pete
Playswithbrass
First Name: Peter
Last Name: McIntyre
Post by Playswithbrass » Mon Feb 22, 2021 7:20 pm
Dan Haynes
Last Name: Haynes
Post by Dan Haynes » Mon Feb 22, 2021 9:30 pm
Donnie's brass manifold is part of a governor when a T engine is used as a power plant. I have the flyball part that goes in the generator hole.
You would open the throttle on the carburetor at a redline setting. The governor, controlling the manifold throttle plate, kept the RPMs in line, opening as needed but returning to reasonable revs when unloaded.
Those who can make you believe absurdities can make you commit atrocities.
-Voltaire
Post by Scott_Conger » Tue Feb 23, 2021 4:34 pm
Now, that makes perfect sense and should have been obvious from the start.
thank you Dan.
