Here are some random surplus parts, some Model T, some not. Feel free to PM or email me with your part(s) of interest, along with a reasonable offer for the part(s) and I will reply with either acceptance or a counter-offer.
Item A is a carburetor inlet warm air shroud and flex pipe. Fits a 2 inch diameter exhaust pipe.
Item B is a Rayfield L2 carburetor that I removed from my Flanders 20 after I found a correct OEM Flanders carb.
Item C is an exhaust cutout. Fits a 2 inch diameter exhaust pipe.
Item D is a brand new brass swing arm designed to clamp onto a 3/8 inch shaft.
Item E is a kerosene tail lamp with good glass - SOLD
Item F is a brass bell crank with mounting flange. It came on my Flanders, but the OEM carb uses a different setup.
Item G is a brass tail lamp mounting bracket.
Item H is a pair of new reproduction 1923-1925 brackets that mount the top front bow to the top of the windshield posts.
Item I is an early, closed end spark plug wrench.
Item J is a pair of brackets for a front fender tie rod accessory. One is original, one was home made to (somewhat) match. I don't have the tie rod.
Item K is a reproduction beveled glass for a side lamp. I bought it from Lang's for one of my E&J lamps, but it was too small, so I don't know what brand it fits.
Items L - T are various brass innertube stem and dust cover parts. None are original Schrader 777 or 888 size.
For Sale, Random Surplus Parts - Make Offer
Topic author - Posts: 2402
- Last Name: Strange
- MTFCA Number: 30944
- MTFCI Number: 23667
- Board Member Since: 2013
Re: For Sale, Random Surplus Parts - Make Offer
One bump before new ads send this one down to oblivion.
The tail light (item E) is sold, thank you Larry! I replied to your email.
