Wanted TT 20" Split Rims
LesAlderson
First Name: Les
Last Name: Alderson
MTFCA Number: 50404
Post by LesAlderson » Fri Feb 19, 2021 9:54 am
Needing 2 split rims for 600/20 tires.
lesjalderson@comcast.net
First Name: Henry
Last Name: Lee
MTFCA Number: 479
Re: Wanted TT 20" Split Rims
Post by Henry K. Lee » Fri Feb 19, 2021 10:16 am
I have some Chevy split rims if you can not find them, let me know.
Hank
Adam
First Name: Adam
Last Name: Doleshal
MTFCA Number: 23809
MTFCI Number: 1
Post by Adam » Fri Feb 19, 2021 11:23 am
TT 23” rims are split rims.
TT 20” rims are solid rims with a removable lock ring.
Last Name: Wrenn
MTFCA Number: 30701
MTFCI Number: 24033
Post by TWrenn » Fri Feb 19, 2021 1:47 pm
From past experience I'm gonna chime in with my 2 cents FWIW...usually not much..😂...but..the 600x20 are also referred to as the "widow maker" due to the danger of the lock ring. Whatever you do if you buy a used set, be DARNED SURE of their integrity. Much rust, and if the lock ring shows any kind of wear or bend, you should pass up. Gotta remember they may be very old and tired and not worth the risk. I ended up buying brand new ones from Universal Vintage tire in Hershey PA, and was glad I did. I searched extensively for used ones and they all were just too rusty and tired looking for me as well as my installer. Just saying. Do what you are comfortable with. And of course inflate them in a CAGE....my late grandparents owned a tire store and one employee got in a hurry and inflated one without the cage and had an arm tore completely off when the ring cut loose.
First Name: Henry
Last Name: Lee
MTFCA Number: 479
Post by Henry K. Lee » Fri Feb 19, 2021 4:36 pm
That’s why I have replaced them with Chevy’s. Safe way to go!
My $0.02 worth,
Hank
LesAlderson
First Name: Les
Last Name: Alderson
MTFCA Number: 50404
Post by LesAlderson » Sat Feb 20, 2021 10:41 am
Thanks for all you input, it is much appreciated.
I am a new to Model T,s and started the fire truck build with just the frame and motor.
tom_strickling
Last Name: Strickling
Post by tom_strickling » Sun Feb 21, 2021 10:39 am
