Magneto Tester - Half Price!
MKossor
Last Name: Kossor
MTFCI Number: 22706
Post by MKossor » Fri Feb 19, 2021 10:02 pm
Make sure your Magneto output is sufficient to properly operate coils.
Magneto Test Result.JPG (41.34 KiB) Viewed 573 times
Add Magneto Test capability to your ECCT coil tester
The ECCT Magneto Test option enables you to check magneto output is sufficient to properly operate Model T coils. Instructions and software needed to enable the magneto test function on your ECCT will be sent via e-mail after purchasing this item. If a software CD is desired or required to enable Magneto test option, an additional shipping charge of $9.75 will apply. (Please note: ECCT coil tester is sold separately)
Expand Your Test Capability
ECCT users equipped with the Advanced Features Software option can also display the real time engine tachometer and numerical values of the magneto output voltage under load and no-load conditions to help diagnose magneto issues. (Note: Advanced Features Software sold separately).
This special offer cannot be combined with any other discount offers. This special offer ends midnight 3/5/2021
50% OFF; $74.95
Place your order here: http://shop.modeltetimer.com/Magneto-Te ... PECIAL.htm
Not familiar with the ECCT? The ECCT is the New Standard for testing and adjusting Model T coils for optimal engine performance.
Learn more here: www.modeltecct.com
Tired with messy Timer maintenance to keep your engine from surging and jerking like crazy?
Check out the Maintenance Free Ideal Timer: www.modeltitimer.com
MKossor
Last Name: Kossor
MTFCI Number: 22706
Re: Magneto Tester - Half Price!
Post by MKossor » Fri Feb 26, 2021 2:46 pm
Only 1 week left to take advantage of this Spring special, ends March 5.
tman12
Last Name: Willams
MTFCI Number: 20566
Post by tman12 » Wed Mar 03, 2021 9:47 am
Mike: Hi From Iowa! I could use one of your magneto testers if available? Thanks John
MKossor
Last Name: Kossor
MTFCI Number: 22706
Post by MKossor » Thu Mar 04, 2021 6:49 pm
John,
Yes, still available. Note that this is an add on Option to an existing ECCT coil tester that enables it to test Magneto output is sufficient to properly operate coils. Together with the Advanced Features Software option, the Magneto test option provides real time tachometer and magneto voltage output under load and no load test conditions.
The ECCT with Magneto Test Option is available here: http://shop.modeltetimer.com/ECCT-with- ... ECCTMT.htm
The ECCT with Magneto Test Option And PC Software is available here: http://shop.modeltetimer.com/Introducto ... CTMTSW.htm
