SUNDAY SWAP MEET
Mark Chaffin
Last Name: Chaffin
MTFCA Number: 31705
SUNDAY SWAP MEET
Post by Mark Chaffin » Sun Feb 21, 2021 1:40 pm
Once again, time for the Sunday Swap Meet! Description and prices are as indicated below. Actual domestic shipping USPO Flat Rate will be an additional charge. Usually $8.50 Small Priority Flat Rate will apply. Combine items and save on shipping. Payment by PayPal (preferred) or check. Message me or call Mark Chaffin (951) 805-0928
1. Block off plate set (Starter, Generator and Bendix) $30.00 :cry: SOLD
2. Front wheel bearing set (2 inners and 2 outers R/L hand thread) $45.00 SOLD
3. Outer bearing set (R/L hand thread) $35.00 SOLD
4. Front bearing race set (inner and outer) $25.00 SOLD
5. Light sockets and thimbles (dual contact) (4) $30.00 SOLD
6. Rear axle bronze thrust washer $7.00 SOLD
7. Headlight socket thimbles NOS (5) $10.00 SOLD
8. Magneto posts (2) $10.00
9. Magneto post with outside oiler outlet (2) $10.00 SOLD
10. Spindle arm set NOS $35.00 SOLD
11. Pedal pad set $5.00 SOLD
12. Transmission band puller $10.00 SOLD
13. Early brass carburetor shut off valve $22.00 SOLD
14. Switch Assembly (Pin Style) $25.00 SOLD
15. Generator mounting bolts NOS (6) $10.00 SOLD
16. Demountable rim bolt and nuts used (32 pieces) $30.00
17. Hub bolt and nuts (40 pieces $25.00 SOLD
18. Brass valve stem, nuts and bridge washers (12 pieces) $35.00
19. Outside oiler parts $40.00 SOLD
Last edited by Mark Chaffin on Fri Feb 26, 2021 4:45 pm, edited 10 times in total.
MTFCA Number: 14972
MTFCI Number: 15411
Re: SUNDAY SWAP MEET
Post by RajoRacer » Sun Feb 21, 2021 2:05 pm
Put my name on the brass carb. shut-off, please !
Mark Chaffin
Last Name: Chaffin
MTFCA Number: 31705
Post by Mark Chaffin » Sun Feb 21, 2021 2:15 pm
Sorry Steve. Missed it by about three minutes. Maybe next time sir! Thank you for your interest though my friend. Much appreciated. :)
Post by Scott_Conger » Sun Feb 21, 2021 4:21 pm
Hi Mark
what are the valve stem numbers?
I may be interested...
halftracknut
First Name: randy
Last Name: lee
Post by halftracknut » Sun Feb 21, 2021 5:13 pm
Mark, I will take #2 and #3 will call you monday am ...thanks
ModelTWoods
First Name: Terry
Last Name: Woods
MTFCI Number: 20180
Post by ModelTWoods » Sun Feb 21, 2021 11:43 pm
Mark, I'll take outside oiler parts, if still available.
Mark Chaffin
Last Name: Chaffin
MTFCA Number: 31705
Post by Mark Chaffin » Mon Feb 22, 2021 10:28 am
Sorry Terry. Someone else beat you to it. Thank you for your interest! :)
Mark Chaffin
Last Name: Chaffin
MTFCA Number: 31705
Post by Mark Chaffin » Mon Feb 22, 2021 10:35 am
Valve stems are off repo tubes for wood wheels. I believe the number is 383.
Post by Scott_Conger » Mon Feb 22, 2021 10:59 am
Thanks Mark
I'll pass
