WTB - Parts for Corcoran carbide generator. For 1914 T. (Parts needed shown in picture)
Topic author - Posts: 7
- First Name: Derek
- Last Name: Eamer
(Bottom picture is not mine, just to help show what I need. Other two pictures are of my actual car and carbide generator.) I’m looking for the brass nut on top with brass clip under it. Also looking for the little lever that tightens/holds the top water tank portion of the generator on. Also looking for correct internal baskets.
- First Name: joe
- Last Name: konarowski
- * REQUIRED* Type and Year of Model Ts owned: 1912 Canadian touring 1915 touring and both on the road
Re: WTB - Parts for 1914 carbide generator. (Parts needed shown in picture)
Would one end off a brass coupler fit that joins two lines together. Just a thought.
- First Name: Derek
- Last Name: Eamer
I hadn’t thought of that, I could try it.
- * REQUIRED* Type and Year of Model Ts owned: 1925 cutdown PU, 1920 Dodge touring, 1948 F2 Ford flat head 6 pickup 3 speed
- MTFCA Number: 52564
More likely a shut off pack nut for a valve. BUT check the thread, maybe non standard. You should list the brand in the title, there were several different makers so they are not all the same. Besides, showing the name might jump out more to viewers.
https://www.modeltford.com/pl.aspx?t=s& ... tor&page=1
1920 Dodge touring
1920 Dodge touring
- First Name: Derek
- Last Name: Eamer
I’ll have to get over to where it’s stored for the winter and take a picture of it. Pretty sure it’s identical to the one in the picture but I’m not 100%. Is the name visible on the generator. I’m fairly new to model t’s, especially gas light T’s.
When you get over to look at it take some photos and post. If not sure what brand post on the forum after you get the photos. You can click on the edit(pencil) and change the photos if not the same.
1920 Dodge touring
1920 Dodge touring
- First Name: Derek
- Last Name: Eamer
Ok thank you. Ill probably be able to get some pictures by Monday. I’ll post and see what everyone thinks it is.
