For Sale: TT Truck Project
Topic author - Posts: 662
- First Name: Ed
- Last Name: Fuller
- MTFCA Number: 29582
- MTFCI Number: 22818
- Board Member Since: 2012
TT Truck Project For Sale
- Steel Enclosed TT Truck cab. Cab was restored and painted years ago by the previous owner. Not perfect, but no rust holes or heavy pitting. Has some dings and scratches from being stored and moved around over the years. The back panel is bent in a little. Shouldn’t be a big deal to straighten out. It is not creased. Doors open and close nicely.
- 1924 Model T Truck Title.
- Correct TT running boards.
- Front Fenders need some work. They have the usual cracks, and dents.
- Nice TT frame, not pitted real bad. Someone repaired the front crossmember in the past and it needs some more work.
- Steel TT flat bed frame with “Ford Truck” embossed on the rear of the frame. I’m pretty sure I have all of the metal strips that go between the
wood planks.
- Hand crank dump mechanism for the bed.
- TT Ruckstell rebuilt by the previous owner.
- Front axle and spindles have new bushings installed.
- One complete set of TT rear wheels with hubs, brake drums, rims, lock rings, bolts, and lugs.
- High Radiator and shell. I don’t know the condition of the radiator.
- Extra rear wheel, rear hub, brake drum, felloe, and wood spokes.
- Three extra front fenders.
- Extra standard TT rear axle.
Truck is located in southern New Jersey. Email me for more information.
$3,000
wood planks.
$3,000
- First Name: Ed
- Last Name: Fuller
Re: For Sale: TT Truck Project
Sale pending
- First Name: Brad
- Last Name: Kirtner
- * REQUIRED* Type and Year of Model Ts owned: 1924 Touring Car, 1927 Closed Cab TT, 1927 Coupe
- MTFCA Number: 50618
It’s because of those fancy new body blocks!
Brad
Brad
- Last Name: Morsher
Yup, the body blocks did it! Nobody buys them sagging. Well bought truck!
- First Name: Ed
- Last Name: Fuller
Truck is sold.
Thank you MTFCA classifieds!
