SUNDAY SWAP MEET
Topic author - Posts: 3346
- Last Name: Chaffin
- MTFCA Number: 31705
SUNDAY SWAP MEET
Good morning everyone! Once again, time for the Sunday Swap Meet! Items and prices are as indicated below. Domestic shipping per item will be $8.50 USPO Priority Flat Rate. Combine items and realize a possible savings on the shipping cost. Payment by PayPal (preferred) or check. Message me or call Mark Chaffin (951) 805-0928.
1. KR Wilson speed bolts $25.00 SOLD
2. Main bearing bolt set $10.00 SOLD
3. Gas tank support brackets (26/27) $10.00
4. Spring perch set $40.00SOLD
5. Spring perch set $40.00 SOLD
6. Tillotson fuel strainer NOS $5.00 SOLD
7. Radiator rod support brackets Ford script NOS $10.00 SOLD
8. Rear axle knock off tool $4.00
9. Metal stem tube nuts (TT) NOS $10.00
10. Commutator wire support clips $10.00 SOLD
11. Drive shaft thrust bearing assembly (Early) $35.00SOLD
12. Drive shaft thrust bearing assembly (Late) $20.00 SOLD
13. 1/2-20 castle nuts new (8) $10.00
14. Emergency brake shoe bolts $5.00 SOLD
15. Ammeter plates (5) $5.00
16. Radiator caps $10.00 SOLD
17. Oil breather cap $8.00 SOLD
18. Coil points NOS (2 pair) $10.00
19. Taillight snap rings NOS (5) $8.00 SOLD
20. Miscellaneous shackles and parts. Good condition. $20.00 SOLD
21. Gas cap aluminum $6.00 SOLDSOLD
22. Radiator cap chrome $8.00
23. Ruckstell shift knob $8.00 SOLD
24. Stewart drive assembly. No cracks. Turns freely. $25.00 SOLD
25. Spare tire lock with no key. $10.00
26. Spare tire lock with keys. Small visible crack on side. $20.00
27. Demountable bolts and nuts $20.00 SOLD
28. Demountable wheel nuts NOS $20.00
29. Timer rollers and New Day brush with retainers $20.00
30. Bumper medallion Ford script $20.00 SOLD
31. Wire wheel spare tire lock nut $5.00
32. Battery clamps $4.00 SOLD
33. Front radius rod to pan studs and nuts NOS $20.00 SOLD
34. Connecting rod bolts $5.00 SOLD
Last edited by Mark Chaffin on Fri Mar 26, 2021 12:56 pm, edited 27 times in total.
- Last Name: Perry
- * REQUIRED* Type and Year of Model Ts owned: 1920 Model T Centerdoor, 1914 Model T Touring
Re: SUNDAY SWAP MEET
I will purchase No. 24. Contact me at jim.perry@mail.com Thanks.
- First Name: Steven
- Last Name: Sebaugh
- * REQUIRED* Type and Year of Model Ts owned: 1924 Touring, 1924 TT Truck
- MTFCA Number: 49646
Sent Email about 10 minutes ago
1924 Model T Touring
1924 Model TT Truck
1930 Model A Pheaton
1924 Model TT Truck
- First Name: Benjamin
- Last Name: Eckstein
- * REQUIRED* Type and Year of Model Ts owned: 24 Roadster Pickup, 13 Runabout, 13 Touring, 14 Light Delivery, 15 Speedster
- Board Member Since: 2012
interested in 21, aluminum gas cap
- First Name: Brian
- Last Name: Dowell
- * REQUIRED* Type and Year of Model Ts owned: 14 Touring 26 Runnabout 19 Canadian Touring
- MTFCA Number: 52162
- MTFCI Number: 205
I would like 4, 5, 10 & 20.
Thank you again
Brian
Thank you again
Brian
Life is Good, be nice.
- First Name: Bill
- Last Name: Serbst
- * REQUIRED* Type and Year of Model Ts owned: 1919 speedster (in progress)
- MTFCA Number: 49936
PM sent.....Thanks!
Bill, Brian and Scott. Reply sent. Thank you.
1, 7, 23 and 34 sold to Tim. Thanks Tim!
- First Name: Dale
- Last Name: Kemmerer
- * REQUIRED* Type and Year of Model Ts owned: 1909 touring 1911 open runabout
I would like 11 & 12 drive shaft thrust bearings will send check. I know I have your address here some place but maybe you better send it again. Thanks Dale
11&12 held for Dale. Email sent.
