FS: 26-27 Radiator Apron
ModelTED
First Name: Ted
Last Name: Hacker
Post by ModelTED » Tue Mar 23, 2021 11:13 pm
Good condition. Bends have repairs. See pics.
$30 + actual shipping
Prefer PAYPAL (friends - so no charges) or check.
ModelTED
First Name: Ted
Last Name: Hacker
Re: FS: 26-27 Radiator Apron
Post by ModelTED » Tue Mar 23, 2021 11:14 pm
More Pics
Post by Allan » Tue Mar 23, 2021 11:21 pm
Ted, there are differences in these. Generally 26-7 types have an extra hole in a recess, below the crank handle hole. This hole takes a set screw which threads into a boss on the front spring Y clip.
Hope this helps avoid any confusion. Allan from down under.
ModelTED
First Name: Ted
Last Name: Hacker
Post by ModelTED » Thu Apr 01, 2021 9:21 pm
Allan, thanks. I got this and several other body parts with a purchased of a running chassis. The frame serial number is 26 and the owner thought the car was 27. Based on what you see, what year is this apron?
Thanks for the help.
Ted
Post by TRDxB2 » Thu Apr 01, 2021 10:59 pm
Thought I would consolidate various references about the
http://www.mtfca.com/discus/messages/41 ... 1414254877
By BRENT MIZE on Thursday, October 23, 2014 - 07:48 am:
Does the 27 radiator apron have an attached thimble behind the crank hole? Mine is missing the thimble, but its an original apron. It has the mounting screw dimple below the crank hole. The repops have the thimble, but mine has no evidence of the thimble ever being there.
http://www.mtfca.com/discus/messages/506218/570049.html
This might explain some unexpected usage http://www.mtfca.com/discus/messages/50 ... 1438099724
26 apron 2.jpg (48.06 KiB) Viewed 496 times
From the encyclopedia http://www.mtfca.com/encyclo/P-R.htm#rad
1924-1926
Some flat tube radiators used during this period. Beginning in late 1925 an optional brass, nickel-plated, shell was offered. During 1926 three and four-row round tube radiators were used in addition to the standard five-row. The bottom skirt was secured to the engine mount/spring clip with a screw. Skirts used with the nickel shell had a nickel trim strip.
http://www.mtfca.com/discus/messages/25 ... 1337348677
side holes
Rad atachmnet.jpeg (50.72 KiB) Viewed 496 times
Post by Allan » Fri Apr 02, 2021 8:33 pm
I have yet to see a decent reproduction of these aprons. Most are semi finished and need bending/tweaking to fit, not to mention drilling. The real failing is they are almost flat, lacking the rounded fullness of the originals. It's great to have them available if one is needed, but they are a pale imitation of the real thing.
ModelTED
First Name: Ted
Last Name: Hacker
Post by ModelTED » Sat Apr 10, 2021 9:22 pm
Wow, thanks all. I appreciate it. Looks like this is a repop. If anyone wants it, please make offer.
Ted
Post by Allan » Sun Apr 11, 2021 6:41 am
No Ted, the second set of photos shows the full curvature of the panel. None of the repops I have seen are made so well as that. It's a nice one, for a 1923-25 model.
Rick_Rice
First Name: Rick
Last Name: Rice
MTFCA Number: 50121
Post by Rick_Rice » Sun Apr 11, 2021 8:26 am
Hi Ted,
I sent you an offer via email and PM.
Kind Regards,
Rick Rice
