WTB E&J carbide generator bracket
Topic author - Posts: 33
- First Name: Wilber
- Last Name: Elliott
- MTFCI Number: 22121
I'm looking for a used brass carbide generator bracket for my E&J carbide tank.
586-651-5760
586-651-5760
- First Name: R.V.
- Last Name: Anderson
Re: WTB E&J carbide generator bracket
I have a bunch of baskets; if you can give me the dimensions of the one you need I may have it.
- First Name: Keith
- Last Name: Townsend
- MTFCA Number: 14778
- MTFCI Number: 16305
RV
I think you need to make an eye doctor appointment.
Thanks RV, but it's the brass bracket that attaches to the running board that I need.
- First Name: Kim
- Last Name: Dobbins
- MTFCA Number: 8243
Bill, most of these brackets I've seen are made of steel.
I just assumed they were brass - thanks for the info Kim! I'm guessing they were painted the same color as the body?
- First Name: Kim
Painted black as far as I know.
- Last Name: Wrenn
- MTFCA Number: 30701
- MTFCI Number: 24033
I would like to FIND an E & J carbide tank (generator)!!Bill Elliott wrote: ↑Sat Mar 27, 2021 10:38 amI'm looking for a used brass carbide generator bracket for my E&J carbide tank.
586-651-5760
PM me if you have one for sale. Thanks. I'll also post a WTB.
- First Name: Colin
- Last Name: Mavins
- MTFCA Number: 1853
The bracket you are looking for is steel with brass knobs that are the same as used on the head lamps
this is my bracket on my 1912 with an E+J generator.-
- First Name: Michael
- Last Name: Abbott
- MTFCA Number: 12345
Here is one for your reference.
I sold a generator with the mounting bracket about 3 months ago on the MTFCA.
Michael A
Michael A
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
I think I have one, will look and get back with you.
Awesome! Thanks Hank!
- First Name: Bruce
- Last Name: Compton
Just curious, but what did the brackets look like for the horizontal mounted carbide tank?
- Last Name: Wrenn
Bruce Compton wrote: ↑Fri Apr 02, 2021 11:57 pmJust curious, but what did the brackets look like for the horizontal mounted carbide tank?
I've never heard of a horizontal carbide tank. Are you referring to the good ol' Prestolite B tank often
seen on running boards, using acetylene rather than carbide? Wish I had one that was full, as nowadays it's impossible
to get one of those old tanks refilled.
- First Name: John T
- Last Name: Tannehill III
- MTFCA Number: 49460
Tim if you go to a welding supply company that fills tanks you can look through their tanks for offset valves and buy the filled tank then you just trade the tank in once empty for another filled tank. Of course you’ll have to pay for the acetylene. They are readily available in my state.
- First Name: Bruce
Tim : A friend has two brass brackets that are meant to hold a cylindrical tank of some sort and was wondering if they are for a T carbide tank.
- Last Name: Wrenn
Thanks John. Already tried that. No luck. So still looking for a decent carbide generator anyway for my '11. Preferably an E & J.JTT3 wrote: ↑Sat Apr 03, 2021 9:09 pmTim if you go to a welding supply company that fills tanks you can look through their tanks for offset valves and buy the filled tank then you just trade the tank in once empty for another filled tank. Of course you’ll have to pay for the acetylene. They are readily available in my state.
Got some possible leads, just need to finish up.
