Spring Carburetor sale
Topic author - Posts: 584
- First Name: Bruce
- Last Name: Compton
- * REQUIRED* Type and Year of Model Ts owned: 1921 Coupe, 1925 Coupe
I have 6 rebuilt, tested and guaranteed Model T carbs. All are set up and ready to install, nor core charges, and all prices include shipping to Cont. USA or Canada. # 1 is a regular Holley NH ('22-'25, but can be fitted with the later adjustment for '25-'27) @$195.00. #2 is a Holley straight through with the brass throttle arm and cast choke arm @295.00. #3 is another Holley straight through with a steel throttle arm and has had a bronze repair to the casting under the bowl (but functions perfectly) @ $250.00. #4 is a U&J carb on an aluminum manifold that works fine but is not a genuine U&J manifold. This particular U&J has provision for the throttle arm to mount on either side of the throttle shaft @ 750.00. #5 is a Stromberg OF with a restored and polished steel needle @$600.00. #6 is another U&J set up with a modified Holley G brass bowl and the correct manifold @ $775.00. Again, all the carbs have been test run, and all include shipping.
- First Name: Bruce
Re: Spring Carburetor sale
The number 4 (U&J set-up) is sold. Thanks MFTCA. i
- First Name: Bruce
Stromberg OF is sold.Thanks MFTCA. Bruce
- First Name: Bruce
U&J #6 is sold as well. Thanks MFTCA. I also have an excellent rebuilt brass bodied ('15-'18) Holley G for $275.00 including shipping
- Last Name: Osterman
Fantastic sale of some great carburetors!
- First Name: Bruce
Thanks Mark. The #1 NH has also sold. Just the two NH straight throughs left plus a very nice '15-'18 brass body Holley G @ $275.00 including shipping.
- First Name: Danny
- Last Name: Deaton
Bruce
I will take number 2 if u still have it
