High tension magneto control switch F/S
Topic author - Posts: 1509
- First Name: Layden
- Last Name: Butler
NOS New Old Stock ( not nicely used but NEVER used or abused) magneto switch for a plain independent magneto like used on Model T accessory magneto drives, this magneto switch makes contact when in the OFF position ( opposite of most switches) to ground and kill a magneto ( will work on most makes of magnetos including Bosch, Splitdorf, Eisemann and so many others), complete and ready to use, tested and works perfectly, 1 3/4" wide. Magneto control switches are not easy to find and usually much more expensive! $99 domestic postage included!
- Last Name: Butler
Re: High tension magneto control switch F/S
Back to the top!
- Last Name: Butler
Back to the top. NICE SWITCH
